Fitting Tips for New Exhaust Header Studs Please
pertonpc
#1 PostAuthor: pertonpc » Thu Dec 01, 2016 8:03 pm
Ok Then,
To compliment my thread on getting a damaged one out -
How do you drive the new stud in deep enough?
How do you prep the hole before fitting?
Is threadlock required so that future nut removal will not undo the whole lot?
Any tips or pitfalls from the experienced ones please.
I can imagine locking two sacrificial nuts onto the stud and driving it in with the two nuts on one socket. But would this damage the new thread or leave a nut stuck on it somehow.
Would applying grease to help it seat all the way in be a no no?
Thanks in advance.
#2 PostAuthor: z1bman » Thu Dec 01, 2016 8:13 pm
just clean out the thread with an 8mm tap then lock two nuts onto the new stud & tighten until it is at the same level as the other studs .do not use any locking agent
Hinckley
#3 PostAuthor: Hinckley » Thu Dec 01, 2016 8:20 pm
I run a tap down the hole and a die down the stud, two nut trick works well, seat the stud short thread in - until no thread is showing.
I use alumslip and no loctite, stainless stud kit.
Gus
#4 PostAuthor: Gus » Fri Dec 02, 2016 9:32 am
Use a top hat nut with a ball bearing inside it.
The nut locks on via the ball bearing then releases easily without having to wreck/stretch any threads
"Set the GRINDER on it"
pertonpc
#5 PostAuthor: pertonpc » Fri Dec 02, 2016 12:30 pm
Nice ideas thanks.
So the new stud will have a long and short thread and the short one goes into the head then (not seen them yet). :?:
needaz1100r
#6 PostAuthor: needaz1100r » Fri Dec 02, 2016 12:46 pm
Gus wrote:Use a top hat nut with a ball bearing inside it.
What a good idea.
Mark.
