ZRX Helmet Lock Frame Dimension Check Please
pertonpc
#1 PostAuthor: pertonpc » Tue Dec 13, 2016 1:44 pm
Hello,
Currently trying to reinstate my rear helmet lock bracket.
Can someone with a standard one give me the inner dimensions of the square hole on the bracket above where the lock sits.
I currently have width 50mm and height 43mm but I can still adjust the height.
Don't want it too short on the height or it will foul the bodywork.
Thanks for looking.
Rhencullen
#2 PostAuthor: Rhencullen » Tue Dec 13, 2016 3:17 pm
It's not possible to check the measurements with the bodywork on - as mine currently stands Mark.
* Looks like I need to paint mine when I do get round to removing the bodywork *
pertonpc
#3 PostAuthor: pertonpc » Tue Dec 13, 2016 3:47 pm
Thanks for looking anyway.
I will report back if I get the size from anywhere else.
Looking at your assembled one there is only a gnat's whisker of clearance so the pics are useful anyhow.
Mark
pertonpc
#4 PostAuthor: pertonpc » Wed Dec 14, 2016 9:23 pm
I have the info now thanks.
Gonna try and set the hole dimensions at 50mm width and 45mm height for starters and see how that goes.
Have more measurements if anyone needs em.
