Good morning.
Got my engine out yesterday and one of the oil cooler hoses looks a bit cracked.
It did not leak before the strip down so it is not too bad, but I thought that whilst tidying it up I would look into replacements.
They are no longer available via Z power.
I have the original standard oil cooler.
Any ideas where I might be able to get them?
Stu
Oil cooler hose replacement 1984 Elr
The bolted flange is silver soldered to the spigot that carries the hose.
The crimp 'cup' is in turn; silver soldered to the spigot, the hose later inserted and the cup is then 'waisted'.
Removing the hose is an absolute git, as is un-soldering the crimped cup without releasing the spigot from the bolted flange at the same time.
Users browsing this forum: floydsz1 and 49 guests
