Right hand a4 caliper bracket
#1 PostAuthor: PAULJAC47 » Thu Mar 02, 2017 5:50 pm
Guyz, pretty sure you can use a left hand bracket for the extra caliper on an a4?
pretty much the only diff i can see is the milled in flats where it locates on the fork mounts,anyone confirm this and whether i need to get these milled in or another way to do?Ta Paul J
8 Valve Mark
Re: Right hand a4 caliper bracket
#2 PostAuthor: 8 Valve Mark » Sun Mar 05, 2017 3:31 am
you're right Paul,they swap right over but like you said; just needs the indent 'spot-faced' using a flat drill bit or milled to suit the contour of the caliper mount on the fork leg..good luck mark
