RS34 MIKUNI Flatslides
#1 PostAuthor: Pigford » Wed Mar 29, 2017 6:19 pm
After a tidy set of RS34's
W H Y
Thanx
Julian_Boolean
Re: RS34 MIKUNI Flatslides
#2 PostAuthor: Julian_Boolean » Thu Mar 30, 2017 12:50 pm
Apart from new, they're like hen's teeth
Julian_Boolean
#3 PostAuthor: Julian_Boolean » Thu Mar 30, 2017 9:17 pm
And in the same day as I posted the above, I've agreed to buy a 2nd hand set of Keihin CR33s for a sensible price
needaz1100r
#4 PostAuthor: needaz1100r » Fri Mar 31, 2017 7:44 am
Pigford wrote:After a tidy set of RS34's
W H Y
Thanx
Not for that lovely tidy 900 surely?
Mark.
martinz1000r
#5 PostAuthor: martinz1000r » Fri Mar 31, 2017 10:21 am
Julian_Boolean wrote:And in the same day as I posted the above, I've agreed to buy a 2nd hand set of Keihin CR33s for a sensible price
Are they the ones from Chris at Grumpy? Cant believe how much they have rocketed in price. They were that price new a couple of years ago.
Julian_Boolean
#6 PostAuthor: Julian_Boolean » Fri Mar 31, 2017 10:36 am
Yep, those ones, wish they were £650 new, RS34s are about £850 new and the CR33s are £1200, I suspect it's because the ones in Britain come via the US, so you get the US $ to Yen exchange rate having an effect and then the $/£ exchange rate effect as well.
You can get them direct from Japan for under £1K, but the import taxes would probably kill that.
Robw
#7 PostAuthor: Robw » Fri Mar 31, 2017 2:13 pm
I bought a set of new cr33 last year only £700. Didn't realise that they had gone up that much.
Rob
Julian_Boolean
#8 PostAuthor: Julian_Boolean » Fri Mar 31, 2017 2:33 pm
As the ones Chris has have turned out to be CR37s, I'm now in the market for carbs again.
slappa13
#9 PostAuthor: slappa13 » Fri Mar 31, 2017 4:58 pm
I have a new set of rs34 for £700
Julian_Boolean
#10 PostAuthor: Julian_Boolean » Fri Mar 31, 2017 5:42 pm
As I seem to be having problems with PMs, I'll have the RS34s
