I used to have my 900's legs turned round anyway so that the calipers went behind.
That's not a problem. I don't have any calipers, need a pair with brackets.
The brackets would have to be as Paul described? RH slightly different to LH?
This is confusing.
Z900 Brake Calipers
- warren3200gt
Re: Z900 Brake Calipers
Okay, so the pair of behind leg ones should do you. Seem to be selling on fleabay for £50 + each. How does £50 + P&P the pair sound?
warren3200gt wrote:Okay, so the pair of behind leg ones should do you. Seem to be selling on fleabay for £50 + each. How does £50 + P&P the pair sound?
Yes that's great, thanks. I'll pm you my address and let me know how much for postage too.
- warren3200gt
Ok Jay,
Just to be clear, to make the pair you will need the right hand one in both photo's. One of which is striped of paint.
warren3200gt wrote:Ok Jay,
No problem, will be refurbing. Will they both be with the bolts that go through the calipers (not the mounting bracket bolts, I have those).
- warren3200gt
Yes they will have all the metal bits. The rubber bits are knackered I should think but I'll check and add anything usable. I'll dig it all out at the weekend.
Brilliant, much appreciated.
Hi Warren I will have the bare Z1000 centre bleed nipple if Jay doesn't want it and you want to sell it. Sean.
- warren3200gt
Sean i think that might be 650. The bleed nipple thread is smaller but thats the only diff i think.
Thanks anyway Warren, I am trying to pair up the caliper from my Z1000 A1.
