Oil Leak ??
BigZCas
Oil Leak ??
#1 PostAuthor: BigZCas » Sat Apr 08, 2017 4:47 pm
Any suggestions appreciated.
I have a slight oil leak, a drip or 2 noticed building along the bottom of the sprocket cover and on the curve of the clutch cable. :(
Also notice some around the top of the gearbox so maybe dripping down.
Can't see that the pressure switch is leaking but hard to tell as new clean oil ?
Any obvious or prone places :?:
thanks
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
Re: Oil Leak ??
#2 PostAuthor: Pigford » Sat Apr 08, 2017 4:54 pm
Cam chain tunnel - alternator wire grommet.....
BigZCas
Re: Oil Leak ??
#3 PostAuthor: BigZCas » Sat Apr 08, 2017 5:29 pm
Just had a look.
The alternator wires are wet and can't see a grommet ?
Have wiped clean and will ride tomorrow and check, looking promising :)
If so, I guess it's just new gasket and grommet ?
Will advise tomorrow :(
Past 5 Years
1976 KZ1000a1, Red
Re: Oil Leak ??
#4 PostAuthor: z1bman » Sat Apr 08, 2017 6:34 pm
probably leaking through the wiring grommet you will need to seal the grommet & the wires will a good quality silicone making sure everything is totally oil free. also check the push rod oil seal
BigZCas
Re: Oil Leak ??
#5 PostAuthor: BigZCas » Sun Apr 09, 2017 6:50 am
Ok thanks
Is the pushrod seal an O ring
There was a broken Oring when I took the cover off but could not work out how it fitted, even had a look at the manual and still can't ? :?:
Past 5 Years
1976 KZ1000a1, Red
Re: Oil Leak ??
#6 PostAuthor: z1bman » Sun Apr 09, 2017 1:17 pm
the pshush rod has a popper seal. the only o ring is behind the sprocket spacer part no 92055-035
BigZCas
Re: Oil Leak ??
#7 PostAuthor: BigZCas » Tue May 23, 2017 5:14 pm
How frustrating ! :evil:
Just when I thought that every leak was fixed ...
Have noticed a small amount of oil building up on the top of the gearbox, when I put the bike on the side stand this then runs down behind the sprocket cover and underneath the frame and cover.
I cannot see any leak coming from the oil pressure switch or chain tensioner tunnel,looks like it is coming from further back ??
Any ideas, can oil come from the breather housing ?
Thanks for any help :(
Past 5 Years
1976 KZ1000a1, Red
Re: Oil Leak ??
#8 PostAuthor: Pigford » Tue May 23, 2017 5:59 pm
Breather housing/oil seperater can leak - it has a large "O" ring where it meets the main casing..... and it's not unknown for it to blow oil into the airbox too!
Zedorset
Re: Oil Leak ??
#9 PostAuthor: Zedorset » Tue May 23, 2017 8:29 pm
z1bman wrote:the pshush rod has a popper seal. the only o ring is behind the sprocket spacer part no 92055-035
That was the cause of a slight leak I had, easily remedied.
1975 Kawasaki Z1B
1979 Triumph Bonneville T140D
1969 BSA B25 Starfire
Re: Oil Leak ??
#10 PostAuthor: ZedHead » Wed May 24, 2017 10:54 am
Alternator loom is common and it is not always just the grommet. The sleeving on the wires break down and start to "wick". Full kits are available from leading suppliers :D
BigZCas
Re: Oil Leak ??
#11 PostAuthor: BigZCas » Wed May 24, 2017 3:56 pm
Oil is on top of the gearbox so oring could be a good shout, i guess that's a carbs off job ?
Dave, do you know anyone that could supply :lol:
Past 5 Years
1976 KZ1000a1, Red
Re: Oil Leak ??
#12 PostAuthor: ZedHead » Wed May 24, 2017 5:11 pm
BigZCas wrote:Oil is on top of the gearbox so oring could be a good shout, i guess that's a carbs off job ?
Hmmm not sure why it would make its way on top of the gearbox? Sound more like breather or oil pressure switch o ring.
http://www.saisei-europe.com/Shop/Produ ... t-z1-z1000
http://www.saisei-europe.com/Shop/Produ ... pan-o-ring
http://www.saisei-europe.com/Shop/Produ ... tch-o-ring
BigZCas
Re: Oil Leak ??
#13 PostAuthor: BigZCas » Fri Jun 16, 2017 6:44 pm
Good shout Mr Pigford,
Changed the large breather O Ring, no more oil on the top of the gearbox :D
Just a slight weep on the alternater wire grommet now :lol:
Past 5 Years
1976 KZ1000a1, Red
Re: Oil Leak ??
#14 PostAuthor: Pigford » Fri Jun 16, 2017 7:26 pm
BigZCas wrote:Good shout Mr Pigford,
Process of elimination... As for alternator grommet, oil can wick out of the cloth wire cover, I just sealed mine using RTV hi-temp silicon (from Debbens, etc), also from the grommet itself. Need to clean the area with brake cleaner (or similar) and seal with silicon stuff - I also used a new COMETIC gasket - worked a treat as bike still dry after +500 miles round trip to YORK Rally :!:
Re: Oil Leak ??
#15 PostAuthor: ZedHead » Fri Jun 16, 2017 7:58 pm
Good result Steve
