1984 Elr carb issue - I think
dave cullen
Re: 1984 Elr carb issue - I think
#16 PostAuthor: dave cullen » Sun Apr 16, 2017 4:52 pm
I would get a bench tested fully rebuilt set from Wired George, fit and forget, then ebay yours
Z900A4 Z1000A1
Stugill
#17 PostAuthor: Stugill » Mon Apr 17, 2017 9:00 am
Dave.
Thanks for the advice, I have looked on their site and it looks very good.
I have asked for a total delivered price to the Uk. I am not 100% what carbs I have and so I have asked them.
Thanks everyone for their help and advice.
Stu
Stugill
#18 PostAuthor: Stugill » Mon Apr 17, 2017 9:32 am
I have added two photos of the two different sets of Carbs that I have got.
As you can see one has a connecting hole and caps, the other doesn't have a connecting hole and didn't have any caps.
Is it as suggested that one might be for the 1100R2? If it is maybe a previous owner upgraded them.
Any advice would be appreciated.
Stu
Carb with the connecting hole
Carb without the connecting hole
#19 PostAuthor: Al » Mon Apr 17, 2017 1:20 pm
Here are some 1000J carbs for comparison. Going to be vaguely similar but there are many variants of the CV including those used by other manufacturers.
With plug and also have the holes as you would expect.
Stugill
#20 PostAuthor: Stugill » Tue Apr 18, 2017 7:01 am
In case the wired George option ^ the USA is prohibitively expensive due to shipping and core fee. Is there anywhere in the Uk that do a similar thing?
Stu
Stugill
#21 PostAuthor: Stugill » Tue Jun 27, 2017 6:04 am
An update,but more questions.
The carbs were ultrasonic cleaned, and fitted them Fri of last week and it fired on all 4 cylinders and sounded good.
I left it overnight and noticed a petrol leak. I looked at it yesterday and changed the fuel line and if I turn the petrol cock to prime petrol leaks from the rear of the carbs. Is this because it is on prime or is there an issue.
Stu
weaver
#22 PostAuthor: weaver » Tue Jun 27, 2017 5:30 pm
prime fills the carbs and relies on the float valves closing to stop the flow sounds like one or more of your valves are passing,maybe not be a problem when tap is in normal position.
#23 PostAuthor: Al » Tue Jun 27, 2017 5:35 pm
There is an issue. The static fuel level is too high. When it floods it usually does the airbox first. Just my opinion but i wouldnt bother setting the static fuel height. Run the engine and with a piece of clear plastic tube on the drain boss, open the drain screws and see what the dynamic fuel level is like. If its correct then you either have; dirt / hair / snott on the float valve and seat or a badly sealing float valve arrangement or just as likely; the 'O' ring around the seat is passing fuel where the seat presses into the body.
Stugill
#24 PostAuthor: Stugill » Tue Jun 27, 2017 7:01 pm
Thanks very much for the advice, I will give that a try.
Stu
#25 PostAuthor: Al » Tue Jun 27, 2017 9:37 pm
This may help, may not. Its pretty old now and very grainy but you get the idea.
http://s254.photobucket.com/user/zorded ... sort=3&o=0
weaver
#26 PostAuthor: weaver » Wed Jun 28, 2017 9:16 am
You may well find the bike performs perfectly with the tap in the on position as prime is never used unless the carbs have been drained it's not a problem
Stugill
#27 PostAuthor: Stugill » Thu Jun 29, 2017 6:38 am
Thanks for the replies, I hope to have a look at the bike today.
Stu
dave cullen
#28 PostAuthor: dave cullen » Fri Jun 30, 2017 9:52 pm
I have just had my ZRX1100 back after several weeks at local bike shop, long tale, but won't repeat it, anyway when I parked bike up, fuel was pissing out the carb to head rubber and it was hunting all over place;
I kept getting messages saying vacuum tap was knackered but when I drained carbs it stopped, and anyway when I lifted tank, no leaks, so it all pointed to air leak;
As I suspected, I had a warped carb rubber, now its been replaced, all ok and running great having had most of the shims done, the bike has only done 4K and spent all its life indoors;
dave
Z900A4 Z1000A1
Stugill
#29 PostAuthor: Stugill » Mon Jul 03, 2017 8:50 am
Cheers.
I am away at the moment so I can't look at it until the weekend.
Stu
swampy
#30 PostAuthor: swampy » Thu Jul 06, 2017 12:22 pm
If your still having issues and would like the carbs referbed to as new standard. Ben Day at vapourworx is your man. He has acess to all the new bits needed including the very rare needles and emulsion tubes for the bs34.
Cost wise you wiuld be looking at approx £630.00
Heres a before and after pic of my z900 carbs he done for me.
Contact details can be found in trusted traders.
Users browsing this forum: r3sc and 41 guests
