Yes, The thread starts at a depth of 10mm
Will give them a call thanks
Fork Tops
Re: Fork Tops
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
1976 KZ1000a1, Red
Re: Fork Tops
z1bman wrote:i am sure the thread on the a1 fork tube is set deeper than the a2 the a2 thread comes nearly close to the top of of the fork tube where the a1 is set about 15mm below the top of the fork tube. the fork tops you have purchased are probably from an early gpz600 which have a similar fork top but they use 37 mm diameter forks. try john browse in wrexham he will know the part you are looking for
The thread on the A2 and D1 is set about 15mm down in tube I have just replaced my Stanchions with a set from Z-power.
