Couple of quick questions
Steve R
#1 PostAuthor: Steve R » Fri Feb 22, 2008 2:19 pm
Got a new front brake light switch as mine hasnt got one, thought it would come with a washer but it hasnt and looking in the parts book there does not seem to be one, is this right? Do I just screw it on or do I use any kind of sealant?
Secondly got some nice PMC billet half moons to put on am I alright just using a bit of blue hylomer on them or should I use something else?
Steve R
KWACKERZ1
#2 PostAuthor: KWACKERZ1 » Fri Feb 22, 2008 3:22 pm
Not sure about the brake switch, But I dont think I would put sealant on it as it may contaminate the brake fluid, Try it dry first.
With regard the the half moons, I often use green hermatite on stuff that wont be removed continually, it sets like harder and is more pressure resistant. (Its used i high pressure steam envioronments).
Garn 1
#3 PostAuthor: Garn 1 » Fri Feb 22, 2008 9:23 pm
Steve R, The brake switch has no washer as it is a tapered thread, which does the sealing. as Kwakerz1 suggests, use only a sealant that won't contaminate brake fluid. I use a very small amount of anti-seize, that would not come in contact with the fluid, if I use any at all.
#4 PostAuthor: Pigford » Fri Feb 22, 2008 9:25 pm
If it weeps, a bit of PTFE tape won't hurt :wink:
Steve R
#5 PostAuthor: Steve R » Fri Feb 22, 2008 9:25 pm
Thanks guys, a job for the weekend
Iain marshall
#6 PostAuthor: Iain marshall » Fri Feb 22, 2008 9:56 pm
Steve watch out with a tapered thread and dont over tighten the switch incase it splits the housing
RALPHARAMA
#7 PostAuthor: RALPHARAMA » Fri Feb 22, 2008 10:11 pm
I'm about to fit my half moons - I thought I'd use silver RTV.
Ralph Ferrand
ROZZER
#8 PostAuthor: ROZZER » Sat Feb 23, 2008 10:27 am
I used black RTV on my half moons (also black) and it's absolutely oil tight.
AKA John Roscoe. PUM #028
1975 Z1B, 1980 Yamaha 350LC
