This is probably a bit of a long shot but I need a cable bracket for a set of vm26 carbs. The set I have came from an early GS850 where the push cable mount is a good 15 to 20mm higher. As a result either the inner cable needs to be longer or the outer needs to be shorter by the same amount.
This is what I've got
and this is something like what I want
Paul
Carb cable bracket
Carb cable bracket
A2 1979-80. A1 1980-now
- warren3200gt
Re: Carb cable bracket
Think you might find it easier to find a suitable cable than mount.
You'r probably right. If only my welding skills were as good as my photoshop skills.
- paul doran
- ZedHead
These two look like the lower one...
http://www.ebay.com/itm/Kawasaki-KZ1000 ... H0&vxp=mtr
http://www.ebay.com/itm/Kawasaki-KZ-650 ... mv&vxp=mtr
This looks like the tall one you have..
http://www.ebay.com/itm/77-83-Kawasaki- ... 56&vxp=mtr
Mark.
Mark.
Users browsing this forum: Simonic and 42 guests
