starter motor
freddyz1r
starter motor
#1 PostAuthor: freddyz1r » Fri May 05, 2017 6:19 pm
Hi all, just found a snapped bolt that fastens the starter motor cover down. As it is on the brushes end, is there any reason why I can't just change the end of the motor and deal with the snapped bolt another day.
Hopefully pics below to explain what I mean. ...
cheers freddy
freddyz1r
PUM 329
Re: starter motor
#2 PostAuthor: Pigford » Fri May 05, 2017 6:29 pm
Swap should be fine...... steel & ally, not a great match :??
freddyz1r
Re: starter motor
#3 PostAuthor: freddyz1r » Sat May 06, 2017 3:27 pm
Pigford wrote:Swap should be fine...... steel & ally, not a great match :??
Thanks for the reply piggy.
I couldn't see why it could be a problem.....but I never can until after :oops:
I'm sure I've got the only tub of copper grease that's ever been produced :D
cheers freddy
freddyz1r
PUM 329
