J/R Clutch push rod
J/R Clutch push rod
#1 PostAuthor: ZedHead » Tue May 09, 2017 3:59 pm
Has anyone got a spare J/R clutch pushrod for reasonable money to help out a customer of mine? Condition is not really important as it is not visisble and will probably be shortened in any case.
davido
Re: J/R Clutch push rod
#2 PostAuthor: davido » Tue May 09, 2017 8:21 pm
I have one from a CSR1000 (81 ish) if thats any good to you. Its a bit chewed at one end but servicable and seemed to work ok when I took it off the bike.
http://www.kzrider.com/forum/11-project ... ject-build
KZ1000CSR
GSF600Bandit
CBX750F
CB550F
#3 PostAuthor: ZedHead » Wed May 10, 2017 1:07 pm
davido wrote:I have one from a CSR1000 (81 ish) if thats any good to you. Its a bit chewed at one end but servicable and seemed to work ok when I took it off the bike.
PM sent
martinz1000r
#4 PostAuthor: martinz1000r » Wed May 10, 2017 2:00 pm
Just buy a length of silver steel rod off ebay and make your own
#5 PostAuthor: ZedHead » Wed May 10, 2017 5:23 pm
martinz1000r wrote:Just buy a length of silver steel rod off ebay and make your own
Anyone know the diameter I would need? Also how are the ends finished?
martinz1000r
#6 PostAuthor: martinz1000r » Wed May 10, 2017 7:20 pm
8mm diameter. Just chamfer the edges off.
#7 PostAuthor: ZedHead » Thu May 11, 2017 8:17 am
martinz1000r, would stainless be ok or is it too soft? Just thinking about corrosion at the exposed end using unplated steel. Would 300mm length be long enough?
martinz1000r
#8 PostAuthor: martinz1000r » Thu May 11, 2017 10:14 am
I just pulled the one out of a Unitrak motor that's on the bench at the moment. That is 310mm long. I'm no expert on these things but i think different models are different lengths plus mine may well be "unique" as i have hydraulic conversions on all my Z motors. On the metallurgy side again, i defer to the experts. Silver steel was a recommendation from another forum member and the rod shows no sign of bending or mushrooming on the ends.
#9 PostAuthor: ZedHead » Thu May 11, 2017 2:16 pm
martinz1000r wrote:I just pulled the one out of a Unitrak motor that's on the bench at the moment. That is 310mm long. I'm no expert on these things but i think different models are different lengths plus mine may well be "unique" as i have hydraulic conversions on all my Z motors. On the metallurgy side again, i defer to the experts. Silver steel was a recommendation from another forum member and the rod shows no sign of bending or mushrooming on the ends.
Excelent! Thanks Martin
#10 PostAuthor: Al » Thu May 11, 2017 2:30 pm
Got one here with one end missing from a 1000R / J3
Assuming both ends are the same (no reason not to) the three parts together sum to 334mm.
Oddly i believed that the Unitrak / 1100R was longer but i know it to be 310mm from previous experience!!!! :rock
#11 PostAuthor: ZedHead » Fri May 12, 2017 7:06 am
Thank you everyone who has offered help and advice. Martin's suggestion to make one seems to be the best solution so this is what I will go with.
Users browsing this forum: Google [Bot] and 28 guests
