Z1100R carbs.
swampy
Re: Z1100R carbs.
#16 PostAuthor: swampy » Wed May 24, 2017 7:52 pm
I shall ask the gent if he still has them.
swampy
Re: Z1100R carbs.
#17 PostAuthor: swampy » Wed May 24, 2017 8:15 pm
soz the 33's have gone but he does still have a set of vm28's.
chrisw1
Re: Z1100R carbs.
#18 PostAuthor: chrisw1 » Thu May 25, 2017 7:30 am
Thanks for checking .... would the 28s be a bit small on my 1000 ?
tlc
Re: Z1100R carbs.
#19 PostAuthor: tlc » Thu May 25, 2017 5:55 pm
Interestingly 34 and 36 rs use the same needle jets apparently.
I chose 34 because I spend most of my time at low speed rather than full throttle.
Super clean carburation out of the box and no apparent loss of top end. 127 rear wheel hp ain't too shabby.
I do not recognise what Al says about the low speed issues apart from the clatter they make.
See how they run https://youtu.be/1mYrZSd53qM
nakasaki
Re: Z1100R carbs.
#20 PostAuthor: nakasaki » Tue Dec 18, 2018 6:53 pm
Hi I know this is an old post but appreciated
I'm thinking of rs34 for my z1100r it's standard motor with Harris pipe
Any idea what main jet to use and air filters looking to try and get this set up quickly and easily regards richy..
