Z900 Top Fork Bolt
Andrew_s
Z900 Top Fork Bolt
#1 PostAuthor: Andrew_s » Mon May 29, 2017 12:34 pm
I plan to remove and replace the top fork bolts on the Z900, but are the springs preloaded?
Andrew
Current Bikes:
2023 R1250 GSA
floydsz1
Re: Z900 Top Fork Bolt
#2 PostAuthor: floydsz1 » Mon May 29, 2017 2:39 pm
They are slightly, put it on center stand and put a chock under the frame at the front, or strap the rear end down so the front wheel is off the ground. Then with a socket just unscrew them. If the wheel is still on the ground then just do 1 at once, very easy to do. Push down on the socket as you get to the last bits of thread, same putting them back, you can push them down ok.
Z1b,
zxr750 m2,
zrx1200
Z1000j lawson race bike,
Versys 1000gt (2019),
floydsz1
#3 PostAuthor: floydsz1 » Mon May 29, 2017 2:42 pm
Oh , don't do it with it on the sidestand or any weight on the front wheel.
Z1b,
zxr750 m2,
zrx1200
Andrew_s
#4 PostAuthor: Andrew_s » Mon May 29, 2017 2:53 pm
Thanks Peter - top tips!
Current Bikes:
2023 R1250 GSA
