UK, Z1a Restoration
BigZCas
UK, Z1a Restoration
#1 PostAuthor: BigZCas » Sun Jun 04, 2017 6:55 pm
Here goes with the first question.
When I collected the bike I was given a swinging arm as the bike had a box section arm fitted.
Have noticed today that there is no grease niple or date stamp ?
Is this off something else or could it still be the original :?? ??
Thanks for any help as I would like to sort before painting.
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
Re: UK, Z1a Restoration
#2 PostAuthor: warren3200gt » Mon Jun 05, 2017 9:32 am
Not really much help but 650's stopped having a grease nipple in about 81, if using the same thinking, all 900's should have them as the latest would be 76 poss reg'd in 77? Z1, Z1A, Z1B & A4's show them as having them in the parts catalogue.
geraldknight
#3 PostAuthor: geraldknight » Mon Jun 05, 2017 6:43 pm
Should have a grease nipple.
#4 PostAuthor: z1bman » Mon Jun 05, 2017 7:12 pm
if you remove the sleeve you should be able to see if it ever had a grease nipple as you will see the threaded hole. it looks like it has been welded over ?
BigZCas
#5 PostAuthor: BigZCas » Mon Jun 05, 2017 8:47 pm
Just had a quick look.
The swinging arm has a needle bearing each side with a sleeve that is held between the two bearings.
There is then an inner sleeve that runs the full width of the swinging arm inside the bearings.
So I guess in this guise the grease could not go anywhere even if there was a grease nipple ? :??
The arm is packed with grease between the inner and outer sleeve.
Past 5 Years
1976 KZ1000a1, Red
#6 PostAuthor: z1bman » Mon Jun 05, 2017 9:41 pm
kawasaki didn't fit needle rollers until the z1000a1 but yours is not from that model
BigZCas
#7 PostAuthor: BigZCas » Tue Jun 06, 2017 1:58 pm
Ok thanks,
Ill fit it up and see how it goes :??
Past 5 Years
1976 KZ1000a1, Red
marmck
#8 PostAuthor: marmck » Tue Jun 06, 2017 2:25 pm
http://www.ebay.co.uk/itm/Kawasaki-Z1-K ... SwLEtYlOiT £200 with postage if your going for original
#9 PostAuthor: ZedHead » Tue Jun 06, 2017 3:46 pm
marmck wrote:http://www.ebay.co.uk/itm/Kawasaki-Z1-KZ-900-Rear-Swing-Arm-Z1A-1974-March-1974-code-403-restored-/222536057946?hash=item33d02ec45a:g:LXgAAOSwLEtYlOiT £200 with postage if your going for original
With duty and tax around £250. Still not too bad and should be solid coming from the States
A1John
#10 PostAuthor: A1John » Tue Jun 06, 2017 5:44 pm
BigZCas
#11 PostAuthor: BigZCas » Tue Jun 06, 2017 6:12 pm
Just spent a couple of hours in my garage fitting the swinging arm.
Removed the box section one and fitted the swinging arm that I got with the bike, all went well..
Suddenly OMG :x :( :cry:
The wheel axle does not fit into the swinging arm slots :!: :!: :lol:
Well you have too :lol:
Axle 20mm, slots 17mm
Thank you all for your help, I will order a replacement from the US immediately :D
Past 5 Years
1976 KZ1000a1, Red
BigZCas
#12 PostAuthor: BigZCas » Tue Jun 06, 2017 6:36 pm
Ordered :D
Past 5 Years
1976 KZ1000a1, Red
