How to stop flash rust occuring
Hi chaps
Quick question for you i have just ordered some deox-c and would like your suggestions to stop flash rust occuring.
I thought maybe a bit of 2 stroke mix swilled around but there may be simpler cheaper methods out there.
Over to you guys.
Over to you guys.
Re: How to stop flash rust occuring
I've been trying this stuff in my A7 tank, it's been in there 24 hours and it's starting to look really good nearly all gone, I'm kind of thinking it took 46 years to get this bad, how concerned do I need to get about it suddenly rusting again
Boiling water might work. Pour in,-pour out,-So hot water evaporates.?
Or WD40 if you're the kind of person who buys it by the gallon. Which is the best way...
ACF-50 doesn't evaporate but by golly it'll prevent rust. Used in the aviation industry. Expensive stuff though
Wouldn't it be better to just seal it as quick as possible with that POR15 liner stuff?
http://www.frost.co.uk/por15-car-bike-m ... ealer.html
Or Petseal - https://www.amazon.co.uk/Petseal-Ultra- ... B006VB6E02
Rinse with some old petrol and coat with Wd40 or 3 in 1 oil.
WD40.... chuck a load in , swill around so it covers every bit. (You can even re-use all the surplace on some other little job
Cheers freddy
Cheers freddy
freddyz1r
PUM 329
freddyz1r
PUM 329
white spirit
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
forget cheap I use this stuff on my jet ski for salt water dogs dangly's
http://www.ebay.com/itm/BRP-293600016-B ... 5B&vxp=mtr
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
As soon as you have rinsed it out and got as much water out use an old cotton tee shirt cut into strips to mop up an more water pull these out the put about a litre of WD or similar in it and swill about, empty out, job done.
thanks for the replys chaps.
deox-c went in the tank yesterday afternoon. how long should i leave it in. would it be safe to leave it inl all week, or should it come out after 72 hours?
I have used Phosphoric acid both inside tanks and on other corroded steel. This http://www.ebay.co.uk/itm/5-LITRE-PHOSP ... Sw9N1VsUEz is 85% which you need to dilute somewhat but it does give fantastic results and at £20 / 5lts delivered it's pretty good value.
swampy wrote:thanks for the replys chaps.
I left it in my A7 tank for about a week, sloshing regularly, with no ill effects, then rinsed with WD40. The inside of the tank looks like new now
I have heard of using phosphoric acid but was worried about damaging paint. ive bought some 2 stroke oil and I will slosh a gallon of 2stroke mix about and see how that goes.
Users browsing this forum: Bing [Bot] and 45 guests
