reproduction wiring looms
z2.john
#1 PostAuthor: z2.john » Mon Feb 25, 2008 9:19 am
Anyone used the repro Z1 wiring looms on a Z900? Was wondering if the change of wiring run from the RH side cover on Z1 to LH on the Z900 causes any problems?
John
cra-z1
#2 PostAuthor: cra-z1 » Sat Mar 01, 2008 6:13 am
I used a reproduction on my 73Z1. found it to be a good product. Not sure about the other half of the question
Garn 1
#3 PostAuthor: Garn 1 » Sat Mar 01, 2008 9:08 pm
John, I believe you would have to modify the Z1 series loom significantly, to make it work. The difference is mainly in getting the extra Z900 fuses in the circuit, hence getting the wires to the position of the original fuse box. It could be made to work by ingnoring these fuse or installing them individually elsewhere.
Read BigFluff comments at "Z thou A1 Loom " (Bike Help a few pages back)*.
RegardZ
Users browsing this forum: Google [Bot] and 31 guests
