Has anyone got or knows where I can get the grommet that fits into the left hand generator casing and allows the stator lead to pass through? It is not listed as a Kawasaki part.
Mine has been mangled in the past and doesn't seal. I have RTV and Kawabond - but would like to make a better job of repairing it before I go to the Z1000 rally in Germany.
Thanks.
Z900 stator lead grommet
- Bill Newman
Re: Z900 stator lead grommet
I've had them before from ZPower.
If you have tried sealing it with RTV it might be the braided wire sheath that is wicking out. If this is the case you will need the full harness kit, available from all good suppliers
- Bill Newman
Thanks guys.
Yes - I have done RTV down the wires but the leak is not caused by wicking. The grommet has been split in the past and looks to have been glued together, so I need a new one.
In the absence of a part no, I did not think of a parts supplier. Now have one on order.
- SVENLEATHER
Bill,
I think I have an old one which might do the trick. Pm me if you need it and I will post it to you.
Sven
Sven
Users browsing this forum: Google [Bot] and 24 guests
