z900 seat foam
z900 seat foam
#1 PostAuthor: Ultim8pc » Wed Jun 28, 2017 12:34 pm
My z900a4 has and Ltd seat fitted. The seat base is in fantastic condition but the foam is not good enough for re-use if I reshaped it. So I am going to recover it with a standard z900 cover, but need a suitable new foam.
Anyone know of anywhere in the UK that sells them?-Haven't seen any on eBay, Z-power Saisei etc...
Re: z900 seat foam
#2 PostAuthor: ZedHead » Wed Jun 28, 2017 1:14 pm
Re: z900 seat foam
#3 PostAuthor: Ultim8pc » Thu Jun 29, 2017 11:28 am
I am assuming that the z1000a foam will do?
Re: z900 seat foam
#4 PostAuthor: ZedHead » Thu Jun 29, 2017 12:16 pm
It just depends on what cover you use. If you are keeping the LTD cover you will need the LTD foam to match. If you are going to buy a Z1000 cover you might be better of getting a full ready made seat.
Re: z900 seat foam
#5 PostAuthor: Ultim8pc » Thu Jun 29, 2017 12:37 pm
I'm planning to use my existing base, fit a standard z900 foam and cover. (Although I didn't make that massively clear in my original post - now edited).
Yes, I could purchase a complete seat, but it'd be less original than re-using the base I have.
Re: z900 seat foam
#6 PostAuthor: ZedHead » Thu Jun 29, 2017 5:55 pm
I have added a range of seat covers for Z1 - Z1000R. I can offer a foam and cover bundle for £170 by request. (Need to figure out how to do it on my website).
http://www.saisei-europe.com/Shop/Produ ... eat-covers
Dave
pertonpc
Re: z900 seat foam
#7 PostAuthor: pertonpc » Thu Jun 29, 2017 7:58 pm
My Z1B came with an ltd seat unit.
When I tried the base against a standard foam & cover it would not fit right.
Be prepared to do some modding to the base to get it to fit right.
Can't remember the exact issue but I ended up down the new seat unit route because of it.
From Mark
Re: z900 seat foam
#8 PostAuthor: Ultim8pc » Thu Jun 29, 2017 9:05 pm
Perton - I was lead to believe the bases were identical. I have a PMC low seat I can compare with..
Thanks for the heads up
Re: z900 seat foam
#9 PostAuthor: Ultim8pc » Thu Aug 10, 2017 6:18 pm
By way of an update. I've actually bought another complete z900. The cover is non-standard and the base is a little tatty. Hoping to re-use the foam from it on mine. I'll then clean and repaint the remaining base to use on another project or sell.
