Z1000R-2
Re: Z1000R-2
#226 PostAuthor: chrisNI » Sat May 20, 2017 11:47 am
More so the early Js than later Js or the R as an issue with new bikes. Any of them can start to smoke a bit once they get a few miles on like any Zed.
Is Vic There
Re: Z1000R-2
#227 PostAuthor: Is Vic There » Wed Jun 21, 2017 7:59 pm
Well my new MTC 1075 piston kit arrived a few weeks ago, the piston and block were taken to a trusted engineer who was recommended by a few Kawasaki people down here, he bored and matched each piston, really nice job. He builds Kawasaki race engines for the period racer lads and drag lads down here, he's also the agent for MTC which I didn't know because he doesn't advertise it!
So if I get time over the next few weeks, fingers crossed touch wood the Z1000R should be up and running and sounding like new, once the engine is finished I've got to check everything again and make sure its safe.
I'll post some pictures up on the weekend.
swampy
Re: Z1000R-2
#228 PostAuthor: swampy » Tue Jul 04, 2017 7:42 pm
I'm doing my z1100r at the mo, its one step forwards painfully slowly at a time.
just because of work v's family v's garage. keep the faith and we will both get there. please post the pics here when its done.
Is Vic There
Re: Z1000R-2
#229 PostAuthor: Is Vic There » Wed Jul 05, 2017 11:03 pm
Hey mate,
I have a couple of mates coming round on Sunday afternoon to help fit the block and head, the rest I can fit myself.
I'll post some pictures up next week, unfortunately I've started not to like the bike and will more than likely sell it when its up and running right.
Is Vic There
Re: Z1000R-2
#230 PostAuthor: Is Vic There » Thu Jul 06, 2017 8:30 pm
Cleared the bench, all parts laid out ready for Sunday, hopefully for the 1st time we'll have her up and running right.
http://i1074.photobucket.com/albums/w40 ... esljym.jpg
http://i1074.photobucket.com/albums/w40 ... sp7qwo.jpg
swampy
Re: Z1000R-2
#231 PostAuthor: swampy » Thu Jul 06, 2017 9:36 pm
2 part head gasket I see, the cam tunnel o ring is mighty expensive over here in blighty.
have ya got a new one or re-using the old one.
Is Vic There
Re: Z1000R-2
#232 PostAuthor: Is Vic There » Thu Jul 06, 2017 10:51 pm
swampy wrote:2 part head gasket I see, the cam tunnel o ring is mighty expensive over here in blighty.
All new seals and gaskets, just got to match the four O rings that go on the top of the barrel, if you want all the old gaskets and seals pm me your address and I'll post them overs, the engine was "rebuilt" so I'm assuming that the seals and gaskets are near enough new, also replacing the cylinder head bolts. You can have all the old stuff if there any use to you.
swampy
Re: Z1000R-2
#233 PostAuthor: swampy » Fri Jul 07, 2017 6:04 am
thanks vic they would be handy.
as for the 4 'o' rings for the oil ways I have found that gs750 items are the same id and thickness.
pm sent
Is Vic There
Re: Z1000R-2
#234 PostAuthor: Is Vic There » Fri Jul 07, 2017 8:42 am
No problems matey got your PM, I'll pop them in the post next week :D
Julian_Boolean
Re: Z1000R-2
#235 PostAuthor: Julian_Boolean » Fri Jul 07, 2017 10:39 am
Are you going to use the standard cam chain tensioner or fit a manual one?
I fitted a manual APE one when I rebuilt my top end as the spring in my standard one had seen better days.
swampy
Re: Z1000R-2
#236 PostAuthor: swampy » Fri Jul 07, 2017 2:30 pm
Are there really any benefits from fitting a manual tensioner on a road bike.
Julian_Boolean
Re: Z1000R-2
#237 PostAuthor: Julian_Boolean » Fri Jul 07, 2017 3:01 pm
swampy wrote:Are there really any benefits from fitting a manual tensioner on a road bike.
I suppose it depends on how good you ride, but what's the point of 1170 High Compression Pistons, Flatslide Pistons and Dyna 2000 ignition on a road bike, if you're spending a whole heap of money on the engine why not spend the extra £50 on a cam chain tensioner that can't back off, it takes 5 minutes to adjust when you're doing a service.
swampy
Re: Z1000R-2
#238 PostAuthor: swampy » Fri Jul 07, 2017 5:59 pm
ok you just described my engine Julian point taken. there is a but though, how do yu know when you have reached the right tension as over tight is just as bad as to loose.
the reason I ask is that I have never effed about with one.
Julian_Boolean
Re: Z1000R-2
#239 PostAuthor: Julian_Boolean » Fri Jul 07, 2017 8:55 pm
I was actually describing my engine
As for judging tension it's a bit of an educated guess, but you can feel when it's right (I hope), though my tensioner spring wasn't tensioning the chain enough so goingbyo a manual was an easy decision.
I think I read a lot of opinions on the internet and had a chat with Chris at Grumpy1260 about how tight to do it as well.
I'll also add that I'll probably take the engine apart again over winter as I think I could do with a new cam chain.
swampy
Re: Z1000R-2
#240 PostAuthor: swampy » Sat Jul 08, 2017 6:56 am
if you buy a cam chain splitter/riveter you wont have to strip the engine.
