swampy wrote:if you buy a cam chain splitter/riveter you wont have to strip the engine.
I was considering getting Tony Galea to do it by splitting the cam chain, he's been doing them since the 80s and not far from here.
Is Vic There wrote:Great day today, fitted the new MTC pistons, still a bit iffy about using 'buttons' rather than circlips but we'll see!
We found that the carb rubbers were really hard so thought we'd replace them as I've got a spare new set from the Harris build, went to undo them and was gobsmacked to find that they were only held on by the top four bolts, this 'Total rebuild' gets better! Like I've said before attention to detail counts but it's better to get the basics right first! While I'm on about the basics, a battery needs checking and will not work without acid in it, so I found out with the Z1100R. Great to know this hadn't been 'restored' at least it will not need an engine rebuild!
