Vacuum taps
davido
Vacuum taps
#1 PostAuthor: davido » Sun Jul 09, 2017 2:39 pm
Fitted a second rebuild kit in my 1000CSR fuel tap a couple of weeks ago. Discovered a pool of fuel under the bike again today.Taking off the tank,the fuel is pissing out all over the place in both 'On' and 'Res' positions.Agin!
Ive read that this is a common fault with old Kawasaki vacuum taps.
Is it worth persevering with it? Could I change it for a manual tap? What about a Pingel?
Any opinions,comments,suggestions appreciated as Im well stuck.
P.S. I refurbished the tap with help from this;
xjbikes.com/forums/threads/rebuilding-th...-valve-w-pics.25058/
http://www.kzrider.com/forum/11-project ... ject-build
KZ1000CSR
GSF600Bandit
CBX750F
CB550F
Charlie
Re: Vacuum taps
#2 PostAuthor: Charlie » Sun Jul 09, 2017 3:34 pm
I fitted a Suzuki GS (750) tap. They are available direct from Suzuki brand new and are not very expensive. Sorted my Z650 issue
weaver
Re: Vacuum taps
#3 PostAuthor: weaver » Sun Jul 09, 2017 5:06 pm
Taps are common to a lot of models you should be able to buy a brand new one with a bit of searching
doebag
Re: Vacuum taps
#4 PostAuthor: doebag » Sun Jul 09, 2017 5:08 pm
Charlie wrote:I fitted a Suzuki GS (750) tap. They are available direct from Suzuki brand new and are not very expensive. Sorted my Z650 issue
Don't let the Number 7 bolt police see that comment. :D
'Dying a'int much of a living, boy'
Outlaw Josey Wales
Member No. 555
swampy
Re: Vacuum taps
#5 PostAuthor: swampy » Sun Jul 09, 2017 5:21 pm
:lol: :lol: :lol:
Kev1R
Re: Vacuum taps
#6 PostAuthor: Kev1R » Wed Jul 12, 2017 7:59 pm
Similar problems encountered with the vacuum tap on my z1000 A2.
I fitted a pingel adapter which I got from the States - plus
a z1000 a1 / z900 style - on/off /reserve style tap which I got from j Browse
I still have the original tap for the a2's next owner but I will not be using it!
010
Re: Vacuum taps
#7 PostAuthor: z1bman » Wed Jul 12, 2017 10:02 pm
aftermarket kits are a waste of time you can still get the genuine parts
johny brando
Re: Vacuum taps
#8 PostAuthor: johny brando » Wed Jul 19, 2017 5:16 am
davido wrote:Fitted a second rebuild kit in my 1000CSR fuel tap a couple of weeks ago. Discovered a pool of fuel under the bike again today.Taking off the tank,the fuel is pissing out all over the place in both 'On' and 'Res' positions.Agin!
HI, I RECON IT'S HORSE'S FOR COURSES !!!! VACUUM TAP IS GOOD IN THE EVENT OF A STICKY FLOAT NEEDLE OR DUFF FLOAT SEAT = NO HYDRAULIC LOCK OR 5 WEIGHT ENGINE OIL ( =FUEL CONTAMINATED & TRASHED BEARINGS ) & THERES ONLY A SINGLE LITTLE DIAPHRAGM TO REPLACE IF IT FAILS !!!! PERSONALLY I SEE THEM AS A PRACTICAL IMPROVEMENT =GLASS HALF FULL.
Users browsing this forum: Google [Bot], r3sc and 41 guests
