Bottom Yoke
BigZCas
Bottom Yoke
#1 PostAuthor: BigZCas » Wed Jul 12, 2017 5:44 pm
OK, Managed to knock the bottom bearing off.
I notice that the half bearing has a shoulder to house the oil seal and the 1mm plate, :o can anyone advise if the up-grade taper bearing kit has the same type of arrangement ?
cheers
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
Re: Bottom Yoke
#2 PostAuthor: z1bman » Wed Jul 12, 2017 7:32 pm
some kits come with a seal & some don't . the pyramid kit has the seals
swampy
Re: Bottom Yoke
#3 PostAuthor: swampy » Wed Jul 12, 2017 7:53 pm
Got mine from z-power and yes the same arrangement does work, cant remember if it was supplied as a kit or I had to by the additional parts. came with hi spec Koyo bearings though. blunt wood chisel works well as a separator for the bearing due to its wedge shape.
swampy
Re: Bottom Yoke
#4 PostAuthor: swampy » Wed Jul 12, 2017 7:58 pm
p.s suitable size gas barrel is the bomb for putting the new ones on. Just make sure the ends are dead square to the wall of the tube.
