Fuel tap with 3 outlets?
My Z900 has a fuel tap fitted with 3 outlets, it looks pretty identical to the standard Z900 tap other than the extra outlet. One of the outlets has a 2" length of hose fitted which is blanked off - any idea what it's originally off?
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
Re: Fuel tap with 3 outlets?
Andrew_s wrote:My Z900 has a fuel tap fitted with 3 outlets, it looks pretty identical to the standard Z900 tap other than the extra outlet. One of the outlets has a 2" length of hose fitted which is blanked off - any idea what it's originally off?
Could be from the later triples (KH's) which changed from the Vacuum tap to the standard Zed type tap only with 3 outlets as in....
http://www.ebay.co.uk/itm/KAWASAKI-KH25 ... SwmLlX2~1-
Garry.L wrote:Could be from the later triples (KH's) which changed from the Vacuum tap to the standard Zed type tap only with 3 outlets as in....http://www.ebay.co.uk/itm/KAWASAKI-KH25 ... SwmLlX2~1-
Thanks Garry, very helpful - I'll replace it as Kawasaki still sell OEM fuel taps for the Z900, not cheap though.
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
Andrew make sure its the one with the outlet pipes at right angles to each other a correct for an a4...Paul J
Andrew_s wrote:Garry.L wrote:Could be from the later triples (KH's) which changed from the Vacuum tap to the standard Zed type tap only with 3 outlets as in....http://www.ebay.co.uk/itm/KAWASAKI-KH25 ... SwmLlX2~1-
If your present one is a gen tap then stick it on ebay as it'll fetch decent money. As I'm sure many will confirm the pattern one's are on the whole pretty crap.
PAULJAC47 wrote:Andrew make sure its the one with the outlet pipes at right angles to each other a correct for an a4...Paul J
Paul, thanks for the tip - I'll make sure it is when it arrives.
Garry.L wrote:If your present one is a gen tap then stick it on ebay as it'll fetch decent money. As I'm sure many will confirm the pattern one's are on the whole pretty crap.
Garry, yes it is an original tap and it works ok and doesn't leak - any idea of its value?
Andrew
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
Andrew_s wrote:PAULJAC47 wrote:Andrew make sure its the one with the outlet pipes at right angles to each other a correct for an a4...Paul J
Paul, thanks for the tip - I'll make sure it is when it arrives.Garry.L wrote:If your present one is a gen tap then stick it on ebay as it'll fetch decent money. As I'm sure many will confirm the pattern one's are on the whole pretty crap.
Andrew
Having placed the order with Kawasaki it now seems Z900 OEM fuel taps are not longer available, so I guess the KH triple one stays fitted for the time being...........
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
