Fuel supply
wayno
Fuel supply
#1 PostAuthor: wayno » Wed Aug 16, 2017 11:35 am
Hi all, last twice while out on the a4, after a number of miles the bike feels like it needs to go onto reserve (plenty of fuel) turning the reserve on cures the problem so I am assuming that the filter on top of the fuel tap is blocked/knackered. I remember seeing them on ebay or maybe somewhere else but cannot find them anymore, any ideas where/if still available, I know I could try and clean it if it's the problem but as it has to come out then ensuring it's eliminated may save time.
Cheers wayne.
Re: Fuel supply
#2 PostAuthor: ADRIAN H » Wed Aug 16, 2017 2:31 pm
Z900A4 fuel taps are better made than the earlier Z1 type, should be an easy fix.
Buy a fuel tap repair kit, replace all the O rings.
If its the filter, these are hard to get hold of. Was told you could use a lawn mower filter, just a thought.
wayno
Re: Fuel supply
#3 PostAuthor: wayno » Wed Aug 16, 2017 4:42 pm
Fitted a repair kit about 2yrs ago which makes me suspect the filter .
wayno
Re: Fuel supply
#4 PostAuthor: wayno » Fri Aug 18, 2017 7:32 pm
Anyone know what diameter the pipes into the fuel tank are??
Re: Fuel supply
#5 PostAuthor: ADRIAN H » Fri Aug 18, 2017 8:20 pm
Fuel lines from fuel tap to carbs are 1/4" internal diameter.
wayno
Re: Fuel supply
#6 PostAuthor: wayno » Sat Aug 19, 2017 3:49 am
Cheers Adrian but I meant the pipes on the top of the tap that protrude into the tank, normal and reserve pipes,
Taffus
Re: Fuel supply
#7 PostAuthor: Taffus » Sat Aug 19, 2017 7:09 am
have you tried opening the fuel cap? Vent may be blocked
Steve Cooke
Re: Fuel supply
#8 PostAuthor: Steve Cooke » Sat Aug 19, 2017 9:09 am
The brass pipe does measure 6mm or 5.97mm on mine to be exact.
wayno
Re: Fuel supply
#9 PostAuthor: wayno » Sat Aug 19, 2017 1:05 pm
Taffus wrote:have you tried opening the fuel cap? Vent may be blocked
Not tried opening the cap, assumed that as it runs fine on reserve then cap would be OK, will try tho.
wayno
Re: Fuel supply
#10 PostAuthor: wayno » Sat Aug 19, 2017 1:08 pm
Steve Cooke wrote:The brass pipe does measure 6mm or 5.97mm on mine to be exact.
Thanks steve
wayno
Re: Fuel supply
#11 PostAuthor: wayno » Thu Aug 24, 2017 11:04 am
Stripped the cap and rebuilt, didn't seem blocked, got a gauze filter from eBay but couldn't find a 6mm one so got a 5mm, too tight but cple min in hot water and it's a tight fit but it's on. Away for a week so try it when I can, fingers crossed.
Wayne.
