Engine Restoration
BigZCas
Engine Restoration
#1 PostAuthor: BigZCas » Wed Aug 16, 2017 6:05 pm
Can anyone help or recommend someone ?
I would like my Z1a engine stripped and the Head and Crank Cases etc blasting, before rebuilding replacing any parts that are required.
Engine has covered 27,000 Miles.
Cas
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
Re: Engine Restoration
#2 PostAuthor: chrisu » Wed Aug 16, 2017 6:25 pm
there a number of us who can do this - depends on what needs doing as to costs.
I'm assuming you want someone local.
BigZCas
#3 PostAuthor: BigZCas » Wed Aug 16, 2017 9:06 pm
As I will have to drop off and pick up, would like within 100 miles of LE67.
Although the main objective is cosmetical, I would want worn items replacing.
Would like to discuss scope of work once someone is established.
Past 5 Years
1976 KZ1000a1, Red
000zeds
#4 PostAuthor: 000zeds » Thu Aug 17, 2017 8:26 am
http://www.aloh.co.uk/
Steve Smethurst does a great job but he is not cheap :!:
I had 2 engines done by him and was really pleased , He does work for Dave Marsden at Z-Power :!:
When a Z1 engine is striped down first things definitely needed are listed below and I brought all them all with the engine
1 x Complete Gasket Set
1 x Cam chain 21070-003 { Non Kawasaki Heavy Duty ones are available costing less than genuine}
2 x Idler Rubber 92075-119
2 x Idler Rubber 92075-120
4 x Rubber Guide Roller 92075-232
1 x Tensioner Assembly 12048-001
1 x Roller 12055-002
2 x Rubber Guide Roller 92075-123
1 x Rod Assembly 12054-001
1 x Spring for Tensioner 92081-107
1 x Guide For Cam Chain 12053-119
I would also consider a new set of piston rings :idea:
Zeds-R-Us
BigZCas
#5 PostAuthor: BigZCas » Thu Aug 17, 2017 11:59 am
Thank you for the information.
Would like a few quotes for comparison :)
Past 5 Years
1976 KZ1000a1, Red
Keefleaf
#6 PostAuthor: Keefleaf » Thu Aug 17, 2017 1:58 pm
Buzzard,- no worries - 'cost effective'
Buzzards done lots for me .
Buzzworx
#7 PostAuthor: ADRIAN H » Thu Aug 17, 2017 7:42 pm
Keefleaf wrote:Buzzard,- no worries - 'cost effective'
Buzzworx
+1. He has a good reputation
BigZCas
#8 PostAuthor: BigZCas » Thu Aug 17, 2017 9:30 pm
PM sent
Past 5 Years
1976 KZ1000a1, Red
ChrisB
#9 PostAuthor: ChrisB » Tue Oct 03, 2017 11:15 pm
I may be too late with this reply but i recently used Dave Cunningham at TSR Vapour Blasting. He's in Sevenoaks, Kent but i UPS'd it to him for around £40 from Nottingham. Very impressed with his work, very clean, and very well cleaned out. Cost somewhere between £250 and £300. Can't be certain as he did a few other bits and bobs for me.
Overall, thoroughly recommended.
