Z900a4 rear hub bearing
Gaz1063
#1 PostAuthor: Gaz1063 » Sun Aug 20, 2017 9:09 am
Can someone tell me the correct depth for the cush side bearing into the housing thanks ☺
Re: Z900a4 rear hub bearing
#2 PostAuthor: z1bman » Mon Aug 21, 2017 5:59 pm
i dont know the depth but when the bearing is fitted it leaves a space of about 12mm & the sprocket carrier fits into this when both parts are assembled
