GPZ1100 Exhaust Flanges
Julian_Boolean
#1 PostAuthor: Julian_Boolean » Wed Aug 23, 2017 1:27 pm
I need some flanges for a Vance and Hines exhaust I've got, the hole needs to be 43mm to go over the lip on the downpipes, the ones I have are 40mm, does anybody have any or recomend somewhwere I can get some made, (I have a template of what needs making)
Re: GPZ1100 Exhaust Flanges
#2 PostAuthor: Ginger Bear » Fri Aug 25, 2017 3:46 pm
Do you have access to a lathe? You should be able to modify the ones you have.
# 104
Julian_Boolean
#3 PostAuthor: Julian_Boolean » Fri Aug 25, 2017 3:58 pm
I do know a man with a lathe, might be the best answer.
