Hi all. Just wondering if anyone has fitted renthal bars to their bike and if so what throttle cable (and probably clutch cable-haven't fitted that yet) did you use. The standard one for the lower type bars is still way too long.
Any thoughts
Long Cables
Carpy,if you have to make up your own top brakeline it is possible to make it up yourself. if you go to Staffs "AUTOHOSE" is the stand to go to (inside) you should get the bits cheaper and ofcourse stainless banjos is the way to go. if the current banjos are the ones to successfully do the job,then take them so yer man can match them.
Users browsing this forum: Bing [Bot] and 43 guests
