Best quality 4=1?
1975-S1C
Re: Best quality 4=1?
#16 PostAuthor: 1975-S1C » Tue Oct 10, 2017 4:46 pm
With apologies to garyd for hijacking your post.
So gentlemen, what d’ya reckon ? Is this a proper Z900 kickstand or a ltd one ? And is it bent, or is it suppose to be slightly curved back like that ?
Paul
#17 PostAuthor: kev edwards » Tue Oct 10, 2017 6:21 pm
looks bent compared to mine.
WP_20170327_14_25_50_Pro (2).jpg (249.13 KiB) Viewed 4870 times
Charlie
#18 PostAuthor: Charlie » Tue Oct 10, 2017 6:37 pm
It's massively bent. I am amazed the bike will even stand up leaning on that !!! :shock: :shock: :shock:
1975-S1C
#19 PostAuthor: 1975-S1C » Tue Oct 10, 2017 6:39 pm
Best get another one on order then ! :lol:
#20 PostAuthor: Ultim8pc » Tue Oct 10, 2017 7:47 pm
Thee sidestand on my 900 is bent like that too....
1975-S1C
#21 PostAuthor: 1975-S1C » Tue Oct 10, 2017 8:28 pm
I’ve ordered another one which should be here on Thursday with a bit of luck. Hopefully that’ll sort the issue out.
We’ll see !
#22 PostAuthor: warren3200gt » Tue Oct 10, 2017 8:28 pm
My 900 one is curved like the one in the pics, my 1000 one is straight. Looks like op may have a 900 one on his 1000?
Graham-A2
#23 PostAuthor: Graham-A2 » Thu Oct 12, 2017 8:40 am
Hi - Back to exhausts... has anyone tried a Marving on their Zed? I was considering what to put on my rebuild Z1000A2 and I quite like the look of these
Present
Red '78 KZ - rebuilt from engine up
Other wheels - Couple of old Guzzi's
Past 1994 - 2010
Luminous Green '78 KZ import [BLE 656S]
engz1b
#24 PostAuthor: engz1b » Thu Oct 12, 2017 12:17 pm
hi, put one on my z1b, look good, sound gorgeous,only downside,have to remove for oil change
1975-S1C
#25 PostAuthor: 1975-S1C » Thu Oct 12, 2017 1:53 pm
Bit of an update. The new one pitched up today. It’s exactly the same shape as the existing one. It also whacks against the frame when it goes back. Weird ! :roll: Guess My only option is to try and make something to stop it from going back so far. Still doesn’t explain why it’s doing that though when apparently it shouldn’t.
wheelysteve
#26 PostAuthor: wheelysteve » Thu Oct 12, 2017 3:03 pm
I had a Z1B with a 4 -1 and the side stand hit the frame on it. Fitted a rubber mounted clamp holding a 1975 "Tax Disc" to prevent the clanking !
You could tap out a 6mm hole in either the stand bracket or if possible the stand itself and fit a grubscrew and lock nut to limit the closed position of the stand.
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975-S1C
#27 PostAuthor: 1975-S1C » Thu Oct 12, 2017 3:47 pm
Funilly enough I’ve just come back in from the garage having done exactly that wheelsteve. I drilled and tapped a hole in the stand and it works a treat !
