Z650 Front discs
RALPHARAMA
Z650 Front discs
#1 PostAuthor: RALPHARAMA » Wed Oct 18, 2017 3:49 pm
I am converting a customers bike to twin discs, but whilst he has a pair of calipers he hasn't got a pair of discs. The discs that came with the calipers are too small in diameter (from memory I think they may have been 275mm and he need bigger 'uns!
Ralph Ferrand
Taffus
Re: Z650 Front discs
#2 PostAuthor: Taffus » Wed Oct 18, 2017 4:06 pm
try kawasakiheaven on ebay they specialise in 650s
Charlie
#3 PostAuthor: Charlie » Wed Oct 18, 2017 4:54 pm
The 4 bolt fixing Z650 twin discs as fitted to C1/C2/C3 etc are all 275mm O.D.
The B models with a single brake caliper and usually spoked wheels had a larger disc.
I "think" it was 290mm but do not have a definitive reference to hand that says to confirm.
The larger rotors with 4 bolt fixings were fitted to single disc models
H1-D (1973)
H1-E (1974)
H1-F (1975)
KH500-A8 (1976)
Z1000-A1 (KZ1000) (1977)
Z1000-A2 (KZ1000) (1978)
Z1000-A2A (KZ1000) (1978)
Z650-B1 (1977)
Z650-B2 (1978)
Z650-B2A (1978)
Z650-B3 (1979)
Z750-B1 (1976)
Z750-B2 (1977)
Z750-B3 (1978)
Z750-B4 (1979)
Z900-A4 (1976)
Z900-A5 (1977)
The 4 bolt fixing 275mm twin discs were fitted to
Z650-C1 (Custom) (1977)
Z650-C2 (Custom) (1978)
Z650-C3 (Custom) (1979)
Z650-D1 (SR) (1978)
Z650-D1A (SR) (1978)
Z650-D2 (SR) (1979)
Dont forget to upgrade the master cylinder as well ... :wink:
HTH :)
#4 PostAuthor: ADRIAN H » Wed Oct 18, 2017 6:38 pm
Think the larger Discs were 296mm.
GIMPieZ650
#5 PostAuthor: GIMPieZ650 » Wed Oct 18, 2017 9:35 pm
I have a 296mm 4bolt disc here if you're interested
Charlie
#6 PostAuthor: Charlie » Thu Oct 19, 2017 12:08 pm
296mm IS the Z650B and all the other models I listed single disc. You must be running calipers in front of the forks I'd wager. Those are the calipers that go with the larger discs and vice versa :wink:
RALPHARAMA
#7 PostAuthor: RALPHARAMA » Thu Oct 19, 2017 6:17 pm
GIMPieZ650 wrote:I have a 296mm 4bolt disc here if you're interested
That would be grand. How much would Sir like?
The one on the other side looks like this. Cheers, Ralph
Ralph Ferrand
GIMPieZ650
#8 PostAuthor: GIMPieZ650 » Thu Oct 19, 2017 6:36 pm
The one I have is un-drilled, and ive no idea what i want for it, make me an offer whats the going rate for a used Zed disc?
Charlie
#9 PostAuthor: Charlie » Thu Oct 19, 2017 7:03 pm
The ones on UK Ebay run from around 35 quid to 44 quid delivered :)
