Carb Cleaner....
Carb Cleaner....
Short of an Ultrasonic bath what would be the best Product/Solution to soak a set of shitty carbs in?.
TIA.
TIA.
Re: Carb Cleaner....
Garry, if you have disassembled the carbs, get them vapour cleaned then use a cleaner in the ultrasonic cleaner, if I remember ginger bear knows the name of the stuff, buggered if I can remember the name of the stuff
Also I have a bath big enough for one carb if you need it
Search ultrasonic carb cleaner update it's there
DavidZ1R wrote:Also I have a bath big enough for one carb if you need it
Cheers David.
I might take you up on the offer of the bath. The carbs on the Triple are full of all kinds of shite.
I'll let you know.
Ta.
Garry.
I have an ultrasonic bath that will take all three in one go, and I have the magic cleaning fluid to go with it!
Pop round with them, you're welcome to stick them in for a clean no problem.
Regards Will
Regards Will
Better offer than mine Will, and I bet he will blagg a brew!
I might even offer him a ginger nut
Big Fluff wrote:I might even offer him a ginger nut
Only one?
I'll be in touch.
An old boy down the road from me made his own cleaning bath with a big placcy storage box and 2 orbital sanders strapped onto the sides. his cleaning solution is hot water and fairy.
The results are good for a heath robinson contraption made from old junk off e-bay.
Had quite a bit of success with white vinegar on old gsxr carbs should work on others I imagine
After a trip down to Darkest Shropshire to see Will B and his Molly Turbo rebuild (Very Nice) my carbs are now lovely and clean after a nice dip in his Ultrasonic Bath. After I polished up the brass bits and evened up the tone with a little R&B they now look fab....
Cheers Will and thanks for all the offers Guys.
............... so what you done with the fourth carb
Pigford wrote:............... so what you done with the fourth carb
HHmmmmm..... so that's why it wouldn't run right.
Once a smoker, it's a hard habit to break
Users browsing this forum: Google [Bot] and 59 guests
