Z1000 Restoration
James Bell
Z1000 Restoration
#1 PostAuthor: James Bell » Fri Oct 27, 2017 5:30 pm
Hi folks thanks for the advice on Engine Cleaning , now I would like to ask who can you recommend for spare parts for Classic Kawasakis , I need a complete rebuild kit for the carbs including airbox intake rubbers , my fuel tank is pretty corroded inside and probably past coating it , has anyone fitted the pattern type tanks that are for sale on EBay and are they a good fit , whats the quality like ?
James
Julian_Boolean
Re: Z1000 Restoration
#2 PostAuthor: Julian_Boolean » Fri Oct 27, 2017 5:41 pm
Z Power
Cradley Kawasaki
CMSNL but the postage is expensive
DavidZ1R
#3 PostAuthor: DavidZ1R » Fri Oct 27, 2017 6:05 pm
Yes z power do all the stuff, offer discount for members, there have been problems with some patten tanks, I have just cleaned out mine which was pretty poor inside, came out like a new pin, coated inside looks new.
#4 PostAuthor: Garry.L » Fri Oct 27, 2017 6:24 pm
.... and another https://www.saisei-europe.com/
Your main problem will be exhausts (If you're going Standard) which are pretty much unavailable without the sale of several vital organs.
James Bell
#5 PostAuthor: James Bell » Fri Oct 27, 2017 7:53 pm
DavidZ1R wrote:Yes z power do all the stuff, offer discount for members, there have been problems with some patten tanks, I have just cleaned out mine which was pretty poor inside, came out like a new pin, coated inside looks new.
Thanks David , I might as well give it a try , what products did you use ?
James Bell
#6 PostAuthor: James Bell » Fri Oct 27, 2017 7:57 pm
Garry.L wrote:.... and another https://www.saisei-europe.com/
Cheers Gary , I am restoring a Mad Max Toecutter Replica bike , so standard exhausts are not needed , thankfully !!( £££,) its got a 4_1 , looks like a Laser pipe , pretty much like the one used on the movie bike !!
James Bell
#7 PostAuthor: James Bell » Fri Oct 27, 2017 7:59 pm
Julian_Boolean wrote:Z Power
Cradley Kawasaki
Much obliged Julian !!!
#8 PostAuthor: Ultim8pc » Fri Oct 27, 2017 10:12 pm
James, I've got a z1000a1 to restore too. Got plenty of spares, so give me a shout if you need anything. You never know I might just have something you need.
James Bell
#9 PostAuthor: James Bell » Fri Oct 27, 2017 10:26 pm
Ultim8pc wrote:James, I've got a z1000a1 to restore too. Got plenty of spares, so give me a shout if you need anything. You never know I might just have something you need.
Thanks mate , am looking for a standard mudguard for a kick off , it will be getting painted so chromework is not important , just clean with no dings or scrapes will suffice . Might be on the lookout for a tank , if the one I have doesn't clean up internally !!
James
#10 PostAuthor: Ultim8pc » Fri Oct 27, 2017 10:35 pm
Unfortunately as my z1000 came in crates and I don't have a front or rear mudguard. However, I do have a z1000Ltd mudguard, it's a bit rusty but should be OK for painting after a clean up. You can have it for nothing if you pay the postage.
I have a few tanks, but trying to decide which one to use for mine....
#11 PostAuthor: chrisNI » Fri Oct 27, 2017 11:05 pm
I got some bits recently from JW Groombridge listed substantially cheaper for those particular parts than either Cradley or CMS,they list a good bit of NOS stock and their site is easy to use too, worth a try in addition to all the above mentioned. Also NRP are good for carb and tap kits I’ve had stuff off them although not for a zed and Andy is very helpful and knowledgeable.
AJAyre
#12 PostAuthor: AJAyre » Sun Oct 29, 2017 8:57 pm
Try a product called metal rescue available on amazon in your tank
I have seen pretty impressive results with it
#13 PostAuthor: Philippe » Mon Oct 30, 2017 5:08 am
Hi James
I use a kit from Restom, a French brand, and I'm very satisfied about the quality.
The kit consists of a degreaser, a deruster and a 2 component resine. It takes about 2 days to apply it, there's a notice how you have to use it but it's written in French. For a Z1000 fueltank it costs about 60 Euro.
The company gives 20 years of warranty if applied correctly (how the F*** do they know how one applied it???) :?:
Anyway I used it several years ago in one of my bikes and it's still there.
Greetings from Belgium
Users browsing this forum: sockpuppet and 35 guests
