Ignition Leads
Re: Ignition Leads
I know others use the wired George mod, but it is not needed if your loom is in good clean un-butchered condition, go with dyna-s or Boyer, they are both good, where plugs are concerned i have had no problems with either brand, but i buy locally and not from the web, if you go Boyer that system will very soon let you know if you need the WG mod.
Re: Ignition Leads
kev edwards wrote:I have just put a dyna s on mine, i put new coils on from Z-power, i won't use dyna coils as they have a tendency to arc and split
I have a set of Dyna coils on my z1000 since the mid nineties sometimes and they have been trouble free
Re: Ignition Leads
AlanB wrote:Thinking of replacing the leads/caps on my 79 Z1000 A2. - Excuse my thickness but with the tank removed, can the existing leads simply be unplugged from the coils or are they fixed to the coils ? Also will both Taylor and Dyna 8mm Leads connect to my coils and what's the difference ? Cheers all.
Leads can be replaced if coil resistance checks out ok and coils not cracked/damaged,careful use of junior hacksaw and stanley knife will expose were they join inside the coil towers,just get some ht lead same diameter and solder on using araldite to seal,new plug caps and Denso plugs preferable in mho too many copied Ngks on ebay.As said wired George mod is ok but better if loom is good and giving full battery volts at coils.Nowt wrong with points but as said Dyna s is a good upgrade and a doddle to fit.Paul J
Re: Ignition Leads
Thanks all - Yeah need to give more thought as the current bog standard set up is running just fine - Might just replace points with some genuine Kawasaki ones and replace plugs with some new Denso's on next service.If there is a prob with the coils in the future maybe that would be a time to consider other options.Cheers.
Re: Ignition Leads
chrisNI wrote:kev edwards wrote:I have just put a dyna s on mine, i put new coils on from Z-power, i won't use dyna coils as they have a tendency to arc and split
+1 I have had Dyna coils on my zed for more than 10 years. No problems.
Re: Ignition Leads
Can anyone confirm whether the standard coils need 7mm or 8mm leads?
The ones fitted at the moment that I'm looking to replace are 7mm.
H2B GPZ900R
Re: Ignition Leads
rickm wrote:Can anyone confirm whether the standard coils need 7mm or 8mm leads?
7mm leads, i too in the past have replaced leads on OEM coils and will do this to my existing old ones so i have a spare set.
Re: Ignition Leads
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Re: Ignition Leads
Dyna S once you've done the 'wired george' mod.
So easy to fit - then forget..............
work fine with the standard coils too
Re: Ignition Leads
has anyone ever used the ignitech ignition system. its a bit cheaper than dyna 2000. i was thinking it may be another option for AlanB.
