Z Thou mc rear prob
Z Thou mc rear prob
#1 PostAuthor: PAULJAC47 » Thu Nov 16, 2017 9:49 am
Guyz,just noticed weep between rear mc seal plastic reservoir and mc upper body,cant see how it comes apart,nowt on diagrams anyone cured this? |Ta Paul J
Re: Z Thou mc rear prob
#2 PostAuthor: PAULJAC47 » Thu Nov 16, 2017 10:16 am
Sorted placcy disc inside lift off,two screws them placcy cylinder comes off,seal looks degraded!!!!!
Cant find this o ring anywhere, anyone got any ideas where to source,nowt on z power,cradly or z1 ent!
its 50mm od,2.5 mm thick...
RGH
#3 PostAuthor: RGH » Thu Nov 16, 2017 11:44 am
did one recently, as far as l'm aware, Jimbo is only one that does them.
he has shiite load unavaible O-rings/seals.
http://redlinecycle.com/Brk%20-%20Mast. ... 0Rear.html
#4 PostAuthor: PAULJAC47 » Thu Nov 16, 2017 12:10 pm
Will try Cheers Bud!
tlc
#5 PostAuthor: tlc » Fri Nov 17, 2017 6:57 am
Paul.
I just let my last remaining o ring go to the member that was looking for one to go in his A2 cylinder.
He didn’t use it.
They are available at any o ring shop.
#6 PostAuthor: PAULJAC47 » Fri Nov 17, 2017 8:38 am
Hi Chris long time no see,did look at generic nitrile rubber jobbies but concerned brake fluid may degrade as could not see any that said brake fluid proof! |Have sourced one from previous suggestion Redline in Usa,he seems to have quite a bit of unobtanium...all the best Chap,what you working on? btw
needaz1100r
#7 PostAuthor: needaz1100r » Fri Nov 17, 2017 10:30 am
https://www.ebay.co.uk/sch/reachenginee ... 7675.l2562
Nitrile - Good resistance to minerial oils and grease, hydraulic oils and non-flammable hydraulic pressure fluids.
Any size you like, delivery next day for pence, I've used them lots.
Let's face it, Kawasaki don't make O-rings, they buy them.
Mark.
#8 PostAuthor: PAULJAC47 » Fri Nov 17, 2017 4:23 pm
http://www.efunda.com/designStandards/o ... 0Fluid#mat
This looks a useful site to cross ref materials...
redzee
#9 PostAuthor: redzee » Fri Nov 17, 2017 4:44 pm
https://www.bearingstation.co.uk/Products/O_Rings
Check these out, I didn't realise that there were so many seals....... :shock:
I've used them with no problems.
Eight valve grunt.
#10 PostAuthor: ADRIAN H » Fri Nov 17, 2017 5:35 pm
redzee wrote:https://www.bearingstation.co.uk/Products/O_Rings
Thanks for the link as I need a few o rings myself
wheelysteve
#11 PostAuthor: wheelysteve » Fri Dec 01, 2017 6:44 pm
I'm going to be overhauling the rear brake system on the Z1R I've recently acquired. Looks like the master cylinder is weeping at the joint between plastic reservoir and ally body.
What is the correct size of o ring under there....is it definately 2.5mm x section and 50mm o/d ?
As far as I can see, it needs to be made from EPDM for the best resistance to glycol based brake fluid.
Any other tips when doing this job...best place for m/c seals etc?
Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
#12 PostAuthor: PAULJAC47 » Sat Dec 02, 2017 10:25 am
Hi Steve,got mine from here he seems to have various rare bits,others have used generic type o rings as long as brake fluid proof,i have fitted this jobby and alls well now,If its the same as a thou one inside reservoir is a plastic drilled disc,hook that out with a right angle pick,two screws under neath that need to come out to enable reservoir to come out,bit of brake fluid on new seal makes it easier to refit...Cheers Paul J
Steve Cooke
#13 PostAuthor: Steve Cooke » Sun Dec 03, 2017 8:11 am
It is preferable to use a new Item if available than any NOS rubber item due to the degrading of the material over maybe forty odd years whether it has been used or not.
Users browsing this forum: Bing [Bot] and 43 guests
