Swinging arm spacer
chrisw1
Swinging arm spacer
#1 PostAuthor: chrisw1 » Thu Dec 21, 2017 7:18 pm
Good evening
I am looking for a spacer that goes between the bushes on the swinging arm on a Z1B
Part number 33036-005
Regards
Chris
Re: Swinging arm spacer
#2 PostAuthor: z1bman » Thu Dec 21, 2017 9:50 pm
chrisw1
#3 PostAuthor: chrisw1 » Fri Dec 22, 2017 7:21 pm
Thanks but they don't have any stock I was in there yesterday
#4 PostAuthor: z1bman » Sat Dec 23, 2017 5:27 pm
Big Fluff
#5 PostAuthor: Big Fluff » Mon Dec 25, 2017 11:02 am
If anyone can supply dimensions I more than likely have one.
Even if I haven't got one I can soon spin one up on my lathe.
Will
chrisw1
#6 PostAuthor: chrisw1 » Mon Dec 25, 2017 2:31 pm
Big Fluff wrote:If anyone can supply dimensions I more than likely have one.
Will
Hi Will
They should be 22mm o/d ..... clearance on 17mm for the bore and 141.5mm long according to the ZPower parts book .... they are interested in stocking them if you make a few
Big Fluff
#7 PostAuthor: Big Fluff » Mon Dec 25, 2017 3:54 pm
I take it they are steel, not ally?
chrisw1
#8 PostAuthor: chrisw1 » Mon Dec 25, 2017 6:16 pm
Big Fluff wrote:I take it they are steel, not ally?
Yes they are but looking at the assembly the bushes are top hat shape so I assume the spacer is just to stop the steel inner bushes " floating " down the swing arm spindle and I can see no reason why they it couldn't be machineable nylon unless anyone can correct me on that
Big Fluff
#9 PostAuthor: Big Fluff » Tue Dec 26, 2017 12:43 pm
Okay, will take a look in the morning.
I could make a few up in ally no problem, but drilling steel at that diameter and at that depth would take some doing.
Will
Big Fluff
#10 PostAuthor: Big Fluff » Sun Dec 31, 2017 9:01 am
Sorry for not checking yet, family commitments etc.
Tuesday is a definite.
chrisw1
#11 PostAuthor: chrisw1 » Sun Dec 31, 2017 2:42 pm
thanks Big ...... I have sourced one in the states should be here in the new year but thanks for your offer
Big Fluff
#12 PostAuthor: Big Fluff » Sun Dec 31, 2017 5:51 pm
I might make a few up anyway if any members are interested :roll:
I couuld knock up say 4 of and see where we go from there.
chrisw1
#13 PostAuthor: chrisw1 » Sun Dec 31, 2017 7:20 pm
Big Fluff wrote:I might make a few up anyway if any members are interested :roll:
The guy who used to make them for ZPower has retired , Im sure they would like some
#14 PostAuthor: ZedHead » Wed Feb 07, 2018 12:16 pm
This guy has 1 metre lengths of 22 od x 2.5mm wall mild steel tubing, fairly easy to cut to 141.5mm lengths i would of thought?
https://www.ebay.co.uk/itm/MILD-STEEL-E ... 2397405225
8 Valve Mark
#15 PostAuthor: 8 Valve Mark » Fri Feb 09, 2018 12:31 am
I've got about 40 metres of 22mm o/d x 2mm gauge seamless stainless tube from a microlight project.im sure i could cut,pack and post to members for £15-£20 ish.depending on whether there is much demand,mild steel, ally or nylon tube will crush with minimal lateral pressure so stainless seems safest option, any enquiries welcome. cheers mark
