Kill Switch
Kill Switch
On my 79 z1000 A2 - Normally should the engine still turnover (but not fire up) when the starter button is pressed and kill switch "off" ? Cheers all
Re: Kill Switch
yes the motor will still turn over
Re: Kill Switch
Umm just noticed mine doesn't - any ideas ?
Re: Kill Switch
My z1000a1 or Z1R doesn't spin over on kill switch either
Re: Kill Switch
just had a look at the wiring diagram & yes your rite the starter feed is cut when the kill switch is of
Re: Kill Switch
thanks mate - appreciated
Re: Kill Switch
When working on turbo zeds, I always reconfigure the wiring so it WILL spin over in the off position.
This is handy so that you can ensure full oil supply to the turbo before flicking over to run position.
Kawasaki GPz750T, Kawasaki ZRX1100R, Kawasaki GPZ1000RX, H**** VF1000RG Rothmans, H**** VF500F2F, H**** CB1100RD, Suzuki GSX1100EFE, H**** XL125K2
Re: Kill Switch
I've wired mine so that the kill switch cuts power to the coils and the Dyna ignition, the starter buttons power is controlled by the ignition switch, this means I can turn the engine over without having to worry about earthing the ignition.
My Husqvarna 610 was wired like this as standard.
