Kill Switch
AlanB
Kill Switch
#1 PostAuthor: AlanB » Fri Dec 22, 2017 6:12 pm
On my 79 z1000 A2 - Normally should the engine still turnover (but not fire up) when the starter button is pressed and kill switch "off" ? Cheers all :wow
Re: Kill Switch
#2 PostAuthor: z1bman » Fri Dec 22, 2017 6:20 pm
yes the motor will still turn over
AlanB
Re: Kill Switch
#3 PostAuthor: AlanB » Fri Dec 22, 2017 6:25 pm
Umm just noticed mine doesn't - any ideas ?
DavidZ1R
Re: Kill Switch
#4 PostAuthor: DavidZ1R » Fri Dec 22, 2017 6:43 pm
My z1000a1 or Z1R doesn't spin over on kill switch either
Re: Kill Switch
#5 PostAuthor: z1bman » Fri Dec 22, 2017 7:21 pm
just had a look at the wiring diagram & yes your rite the starter feed is cut when the kill switch is of :bop :bop
AlanB
Re: Kill Switch
#6 PostAuthor: AlanB » Fri Dec 22, 2017 10:07 pm
thanks mate - appreciated
Big Fluff
Re: Kill Switch
#7 PostAuthor: Big Fluff » Mon Dec 25, 2017 10:59 am
When working on turbo zeds, I always reconfigure the wiring so it WILL spin over in the off position.
This is handy so that you can ensure full oil supply to the turbo before flicking over to run position.
Julian_Boolean
Re: Kill Switch
#8 PostAuthor: Julian_Boolean » Mon Dec 25, 2017 5:27 pm
I've wired mine so that the kill switch cuts power to the coils and the Dyna ignition, the starter buttons power is controlled by the ignition switch, this means I can turn the engine over without having to worry about earthing the ignition.
My Husqvarna 610 was wired like this as standard.
