Throttle response
Re: Throttle response
No air filters, no air box, just aluminium velocity bells, and a GPZ 1100 full standard exhaust system, but I’m looking for a good replacement exhaust or silencer to fit to the bike. cant afford a new Kerker system . So alternative recommendations would be fantastic
**DT80, CB250rs, GT750, CR500, CR250, DR800, Tiger800, Daytona675, XT550, KZ1000j1, KZ1100r1.
The Delvic stainless steel 4-1 are good value for money.
Julian_Boolean
ADRIAN H wrote:The Delvic stainless steel 4-1 are good value for money.
I think the downpipes are a little bit small diameter for an 1100R (they're correct for a Z1000J) so you'll get good midrange but won't get as much top end as you would with a Kerker or Vance and Hines, the downpipes are a little bit long as well, which will again boost the mid range at the expense of the top end.
Julian_Boolean wrote:ADRIAN H wrote:The Delvic stainless steel 4-1 are good value for money.
Another good thing about them is that you can access the oil filter without removing everything
H2B GPZ900R
Julian_Boolean
rickm wrote:Julian_Boolean wrote:ADRIAN H wrote:The Delvic stainless steel 4-1 are good value for money.
Another good thing about them is that you can access the oil filter without removing everything(at least on a J you can !)
And on an 1100R, they look like a copy of the Kerker road pipe that was supplied with US market 1000Rs just with slightly smaller downpipes, you can buy just the front pipes and use a straight pipe for the rest of the exhaust, I've done this with my Kerker, I think the pipe, a baffle and mounting clamp came to under £30, it sounds good, no idea what it'll ride like until April
Users browsing this forum: No registered users and 214 guests
