Engine Brackets
BigZCas
Engine Brackets
#1 PostAuthor: BigZCas » Mon Jan 29, 2018 6:56 pm
Ref: Z1a
Please could anyone advise what size the Hex Head should be across flats for the 8mm bolts that go through the engine brackets into the frame and the 2 longer 8mm bolts that go through the front bracket. 12mm or 13mm ?
The original ones on my Z1000 are 13mm A/F but the ones I ordered for the Z1 came at 12mm A/F :??
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
z2.john
Re: Engine Brackets
#2 PostAuthor: z2.john » Mon Jan 29, 2018 7:05 pm
13mm is correct
