Start Button
AlanB
Start Button
#1 PostAuthor: AlanB » Sun Feb 18, 2018 5:28 pm
The start button on my z1000 has broken and fallen off - ordered a replacement from ZP and see it has a lip so assume you need to access from inside - How easy is it to access to replace ? Cheers all.
Re: Start Button
#2 PostAuthor: kev edwards » Sun Feb 18, 2018 5:46 pm
easy Disconnect cables from carbs remove whole assembly and undo a couple of screws slide out, slide new one in, takes longer to do all the other stuff than it does to replace the button.
8 Valve Mark
Re: Start Button
#3 PostAuthor: 8 Valve Mark » Mon Feb 19, 2018 12:13 am
keep a wee 6/7"mm screwdriver handy to compress the buttons' spring n wiggle the new button in, release the spring.. done. I :lol:
jphaynes669
Re: Start Button
#4 PostAuthor: jphaynes669 » Mon Feb 19, 2018 6:00 am
Doddle. :sad :up
Jeff.H
