As I continue with braking the abandoned project I have been putting items on eBay,but a few parts may be of use
Now on eBay as a job lot
z1000R2/Z1000J parts (even more added )
Z1000 MK2
Z1300 DFI
Z1300 DFI
Re: z1000R2/Z1000J parts
I’d have the sprocket cover. pM sent
PM sent regarding exhaust collers and colletts thanks.
Looking for some indicators and Elr fairing and headlight
Re: z1000R2/Z1000J more parts
Z1000R/ z1000J /Z1100 Shaft Crankshaft £60 posted
Z1000 MK2
Z1300 DFI
Z1300 DFI
Re: z1000R2/Z1000J parts (more added )
I will take the starter motor Gavin......please
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Z1000R Wheels (Pair)will fit other models Now £80 collection or £110 posted
The wheels have a few marks and scratches but not to bad considering their age,
The spacers are in situe
The rear wheel is larger than the standard Z1000J1 and J2 wheel but is often used as an upgrade on these bikes so I have been told
The tyres are perished and will be removed , this also allows the wheels to be posted (collected the tyres will be on)
Due to the weight restrictions they will be posted as separate items
The postage is for both wheels or you can pick them up yourself and save £30
Z1000 MK2
Z1300 DFI
Z1300 DFI
Re: z1000R2/Z1000J parts (even more added )
Gavin.
If the sprocket carrier and cush drive are still available I will have them.
Stu
Stu
