Z1a Restoration
Re: Z1a Restoration
The Copex that I use is 32mm, it's a flexible hard plastic, the inner and outer sleeve can both be used as both are split along the length, the diameter is not really an exact science as masking tape could be used to stop rotation.
'O'Ring chain first used on the Z1b.
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
1976 KZ1000a1, Red
Re: Z1a Restoration
Well done Steve it looks awesome. MOT next and Stafford Show in October
Re: Z1a Restoration
Very nice, Buzzard is doing a head for me at the moment. Hope is turns out like that.
Re: Z1a Restoration Latest
Carbs are now fitted, all went well
Spent a little time neatening the cable routings.
Plan to spend some time in the evening during the next week fitting the exhaust and hopefully ready for first start up next weekend
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
Re: Z1a Restoration
Looking sweet Steve
Re: Z1a Restoration
Fitted the exhaust tonight.
The method I used was to ask Julie for a hand
Bit of grease on the copper washers to hold them in place.
Placed the connecting rubber on the inside (bottom) Exhaust.
Whilst I lifted the front of the inside pipe into place Julie lifted the rear and put a screwdriver through the mounting bracket on the exhaust and through the exhaust hanger,I then loosely fitted the clamp.
Outside exhaust exactly the same, I lifted the manifold end into place whilst julie held the rear of both exhausts removed the screwdriver made sure both exhaust were in the connecting rubber and then inserted the screwdriver back through both exhaust and the hanger.
WHAT A GAL
Again I loosely fitted the exhaust clamp.
I then removed the screwdriver and inserted the bolt.
Tightened up the clamps, tightened the connecting rubber, tightened the bolt.
Otherside repeat.
WHAT A GAL
Otherside repeat.
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
JamesH_Sussex
Re: Z1a Restoration
That is looking superb mate. Top work.
Re: Z1a Restoration
Hi Steve
people who work on old Zeds should have an extra pair of hands when putting the exhausts on. Lucky you have Julie to lend you that extra pair!
Well done, she's looking stunning !
Greetings
Greetings
Re: Z1a Restoration
Looking good BigZ.
Re: Z1a Restoration
So when are you starting the restoration?
Bloody nice job that Steve
Re: Z1a Restoration
Well it seems my first restoration is coming to an end ....
Hopefully I can get out tomorrow and get some fuel for start up.
Fit Mirrors.
Clean the ACF50 off all the Chrome and Polishing.
Start up
If all goes well I will get it outside and take some proper photo's
Fit Mirrors.
Start up
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
Re: Z1a Restoration
Crackin' bike - Best colours & model buy a mile
Re: Z1a Restoration
Cracking job you've done there!
Re: Z1a Restoration
Started first press
Turned it over a few times on the starter without petrol.
Re-checked oil and topped up as oil pump and filter had now been filled from engine turnover.
Added petrol, checked for leaks, pressed the button.......
AND SHE'S AWAY
Would like to thank members -
Zedhead, Dave at Saisei for all his advise and contacts. (And Parts
Buzzard at Buzzworkz for Engine Restoration.
DaveZ1 for the Carb Restoration
Zedman for Switches Restoration.
Al Marshall for Clocks Restoration.
And loads of other members on here who helped greatly along the way, could never have done it without the club.
No ride out today as weather sh*t, but will post pictures on a new thread once we get out
AND SHE'S AWAY
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
Re: Z1a Restoration
Very happy for you. Here's hoping for some decent weather soon!
Users browsing this forum: Andy M and 55 guests
