Z900/Z1000 piston ring compressors - Is there a difference?
Shed20a
#1 PostAuthor: Shed20a » Thu Mar 06, 2008 11:42 pm
Good evening all,
I can feel this is a stupid question even as I'm typing it out, but I have to ask anyway...
I had a Wiesco 1015 kit fitted to my Z1B a couple of thousand miles ago, and I now have a weeping cylinder base gasket that needs replacing. I have a standard 903cc piston ring compressor that I've used up until now, but the cc of my engine is now 1015 which is the same as the Z1000, and Kawasaki supplied a different piston ring compressor for the Z1000 - Can I still use my 903cc piston ring compressor to refit the 1015 pistons into the barrels after I've replaced the base gasket? Or do I now need to use a Z1000 piston ring compressor?
Any advice would be much appreciated.
Cheers, Stuart[/img]
Work to ride, ride to work...
RALPHARAMA
#2 PostAuthor: RALPHARAMA » Fri Mar 07, 2008 12:02 am
If it isn't OK ... then cut up a biscuit tin into 3/4" strips the circumferance of teh pistons with tin snips. Get a second pair of hands. Cut up 4 thin bits of wood 1/4" x approx 1 - 1 1/2" x 3" ish. Do the inner two pistons first. Prop the piston skirts with the wood to keep them square. Wrap the tin strips around the rings holding them in and holding the strips in place with cable ties. As you drop the barrels down the strips will be displaced as the pistons and rings go into the bores. Much cheaper than ring compressors and work a treat. :D Hide the evidence at the end or yer missus will give you an ear bashing :lol:
Ralph Ferrand
steve f
#3 PostAuthor: steve f » Fri Mar 07, 2008 7:45 am
i use fingers and a screwdriver
Shed20a
#4 PostAuthor: Shed20a » Fri Mar 07, 2008 8:07 am
Thanks for the advice guys. I think I prefer the biscuit tin technique to the fingers and screwdrivers though!
Many thanks for replying.
Z1RII
#5 PostAuthor: Z1RII » Fri Mar 07, 2008 8:10 am
will work fine, i do use the 900 compressor for all bike up to 1100 unitrak. don?t press it too heavy and it will work great.
roll on!
amir
RALPHARAMA
#6 PostAuthor: RALPHARAMA » Fri Mar 07, 2008 8:11 am
:roll:
Remind me not to buy any of your ex bikes/engines :press
Ralph Ferrand
Z1RII
#7 PostAuthor: Z1RII » Fri Mar 07, 2008 8:12 am
:lol: :lol: :lol: :lol: :D :D :D
scott
Junior Section leader
#8 PostAuthor: scott » Fri Mar 07, 2008 11:11 am
Use your fingers mate.....you can feel them slip in nicely.
#9 PostAuthor: Pigford » Fri Mar 07, 2008 7:16 pm
Fingers work well, with a deft touch, its all in the wrist action :wink:
RALPHARAMA
#10 PostAuthor: RALPHARAMA » Fri Mar 07, 2008 7:54 pm
Rings are tooooo expensive to take chances with these dayz! I've put plenty of engines together using the wrong/no toolz in my yoot .... but I know better now. :)
Ralph Ferrand
#11 PostAuthor: Rich » Fri Mar 07, 2008 8:13 pm
Fingers and magnum sticks - you get the benefit of having to eat the ice cream first :D
Garn 1
#12 PostAuthor: Garn 1 » Sat Mar 08, 2008 4:36 pm
Shed, as Z1RII has stated, the 900 compressor will work, there will probably be, a little trouble getting it aligned with those piston wires, because Wisco have different dimensions to standard pistons.
The hardest thing will be getting the rings in, if there is insufficient lead-in taper on the sleeves. This is the usual problem. Biscuit tins, ice-cream stick & golf tees always work, however, that ring compressors makes the job easy.
Regardz.
Shed20a
#13 PostAuthor: Shed20a » Sat Mar 08, 2008 7:33 pm
Thanks a lot for all the advice guys. I must admit the more I've read here the more I wish I'd left my bike at 903cc! Mind you, the extra ccs have been fun. If you think it's possible for me to carry on using my 903cc piston ring compressor then that's what I'm going to try. If it doesn't work out than I can go on a comfort eating binge, and then try the biscuit tin and Magnum lolly stick route...
Users browsing this forum: Bing [Bot] and 40 guests
