Hello chaps,
I’ve seen somewhere that you can make a replacement clutch push rod from silver steel rod, is that right ? If so, can anyone tell me the sizes I need ? I think it’s 8mm ? But not sure of the length. It’s for a Z900 by the way.
If not, no worries, but I was hoping to make one up ready to fit before I dissemble it.
Paul
Clutch push rod info
- ZedHead
Re: Clutch push rod info
Length=288.5mm
Diameter=7mm
Diameter=7mm
Splendid. Thanks Steve
- ZedHead
To be exact the diameter of an original one measures at 6.91mm and a new one measures 6.95mm
