ELR CR29 setup?
RALPHARAMA
ELR CR29 setup?
#1 PostAuthor: RALPHARAMA » Mon May 21, 2018 3:30 pm
I have a friend who I got a set of CR29s for his '93 Z1000R2. It's running like a bag of shite with the baseline setup - really lean on the needles and mega rich on the mains. I don't know what needles were fitted, but the mains are 128s which would explain the richness on the large throttle opening. The bike has a fairly empty Harris pipe and stock air box. He's looking for a nice road ride, not balls out drag race settings.
Anyone got any sweet jetting suggestions for this bike?
Ralph Ferrand
Re: ELR CR29 setup?
#2 PostAuthor: chrisNI » Mon May 21, 2018 4:19 pm
It’s probably rich because of the stock air box the CRs are normally designed to run stacks I don’t think 128 would be massively rich without the air box. CRs can be tricky to set up, they don’t seem to respond well to vacuum gauges either. A Dyno is a big help rather than guessing :shock:
RALPHARAMA
Re: ELR CR29 setup?
#3 PostAuthor: RALPHARAMA » Mon May 21, 2018 4:44 pm
Thanks for your reply Chris.
The bike is at the dyno currently and the guy there says it's absolutely miles out. I balanced the carbs up when I fitted them with my electronic vacuum gauges and didn't have any issues; easier than Mikuni flat slides to be honest. I don't like bell mouths for road bikes as they suck all manner of crap in :shock:
Ralph Ferrand
Re: ELR CR29 setup?
#4 PostAuthor: Ginger Bear » Mon May 21, 2018 8:26 pm
Ralphy,
Just moved this to bike help.
I can't see the option of high performance carbs and the safety of an airbox go 'hand in hand'.
# 104
Re: ELR CR29 setup?
#5 PostAuthor: ADRIAN H » Mon May 21, 2018 8:38 pm
You could talk to Ray Debben @ Debben performance. He set my CR31 up. But they are fitted with velocity stacks and mesh.
Users browsing this forum: Google [Bot] and 35 guests
