z1-z900 Rear Wheel Hub Wanted
A1John
#1 PostAuthor: A1John » Thu May 24, 2018 11:48 am
z1-z900 Rear Wheel Hub Wanted, just found out mine is from an H2 750 :sad
scotty m
Re: z1-z900 Rear Wheel Hub Wanted
#2 PostAuthor: scotty m » Fri May 25, 2018 1:38 am
only difference is the holes to locate the rubbers
samspoons
#3 PostAuthor: samspoons » Fri May 25, 2018 5:42 am
Yes i believe the 72 z1 and early h2s have rubber cush drive mounting holes in the center and later models are to one side. Other than that i think no difference
scotty m
#4 PostAuthor: scotty m » Fri May 25, 2018 6:47 pm
72 z1 were to the side as well
