Hi
I got stitched up on eBay (surprise huh) a caliper pair I bought years ago look like KZ900 but the bleed nipple is angled rather than vertical like the original.
Of course the metal feed pipe that inserts into the original caliper to a depth of 10mm is too short for the new calipers so is useless!!!
Having spent some £££'s getting the dual disc kit from Z-power (bless their patience) I need a right hand caliper that has a feed pipe depth of 10mm.
Cash waiting for the right part ASAP please. I would post a photo of what it looks like but all I see is ""2image0000 tesxt) no simple way to post a photo here
thanks
Phil
KZ900 R/H Caliper needed. Cash Waiting
- paul doran
Re: KZ900 R/H Caliper needed. Cash Waiting
actually posting photos has never been easier.
on post (or reply) click on the attachments tab.
click add files
select image
wait until its loaded - green tick
hit submit
click add files
select image
hit submit
Am not familiar with he phrase "PM sent"?
I see no "attachments" tab ( only "b i quote code list list - * img URL normal Font colour image) listed above the box when replying
where is the attachment?
thaks
thaks
clicking on "img" does nothing but place in the reply. No box opens up with a link to hard drive.
I do not usually have a problem with sending attachments with most applications I use. Only in here
Clicking on any bitton only places text in the reply body. Very odd
Code: Select all
[list][list=][*][img][url][image][/image][/url][/img][/list][/list]
[quote="Phil50"]Am not familiar with he phrase "PM sent"?
It means some one has sent you a private message. Ie they have a caliper for you
If you look under the search box on the right hand side click on private message
Under the box which you type in there is a tab marked
“Attachment “
Click on this. another tab appears
“Add files”
Click on this.
Load picture from computer and submit.
“Attachment “
“Add files”
Click on this.
Also. this thread should be in the wanted section...
I have sussed the photos bit
This is the caliper I need and one is on its way to me. I thank all who helped. If the caliper that arrives has any problems I will try again.
I think it will be fine though.
Cheers all!
Phil
Cheers all!
Phil
Users browsing this forum: Stugill and 45 guests
