1100R forks/brakes
scotty m
1100R forks/brakes
#1 PostAuthor: scotty m » Mon Jul 02, 2018 9:36 pm
can anyone tell me the distance between the front brake disc and the caliper mounts
the eliminator forks i fitted look exact in every way to the stock ones but my brake caliper mount bracket touches the disc when i tighten the bolts, i was thinking maybe because the eliminator has a different wheel size or i have the wrong calipers
thanks
Re: 1100R forks/brakes
#2 PostAuthor: z1bman » Tue Jul 03, 2018 7:38 am
are the caliper mounting brackets steel or aluminium ?
scotty m
#3 PostAuthor: scotty m » Wed Jul 04, 2018 8:14 pm
they are steel with 5 holes in them other than the mounting holes
#4 PostAuthor: z1bman » Thu Jul 05, 2018 6:15 am
if you have the steel carrier they are the correct calipers
Rog
#5 PostAuthor: Rog » Thu Jul 05, 2018 12:48 pm
From fork leg mounting lug to disc is 14mm (caliper removed for measurement :idea ), caliper mounting bracket is 6.2mm thick, these are as close as I can get give or take .0*mm
Measurements were taken a couple of times so they're pretty accurate I hope
No longer searching.......
scotty m
#6 PostAuthor: scotty m » Fri Jul 06, 2018 4:53 am
awesome, thanks so much for your help
